Z5U capacitor upgrade?
greg788 · 2651
Offline greg788
on: October 12, 2022, 10:22:07 AM
Are there any suitable caps like polystyrene or silver mica that can sub for the Z5Us at the output? Can these even be upgraded? What's the goal of the Z5Us there, filtering RF and other HF hash?
Reply #1 on: October 12, 2022, 10:26:42 AM
Yes they are for filtering RFI. The Z5U is the best cap for the job. Don't use polystyrene of silver mica. They are not the best cap for the job.
Reply #2 on: October 12, 2022, 02:43:40 PM
These are also not in the signal path.
Offline greg788
Reply #3 on: October 12, 2022, 04:15:19 PM
To Paul B. -- they appear to be in the signal path since they're on the same signal ground as the 220uF / 16V cap that does make a difference?
Also, while I haven't studied a lot of circuit diagrams, I don't ever recall seeing those on the output of the diagrams I have looked at. Why are those needed in this instance?
Reply #4 on: October 13, 2022, 04:15:02 AM
These provide a path for RF on a cable shield to return to earth through the chassis plate and earth safety ground at the RCA input jacks.
Between the audio ground and chassis there is a pair of antiphase diodes in parallel with a resistor and another 0.1uF Z5U cap to provide some separation between earth and the audio ground for noise rejection purposes.
 If their presences bothers you visually, you can clip them all out of the circuit and not use them at all. (Mostly because they don't handle any signal current)
« Last Edit: October 13, 2022, 04:17:30 AM by Paul Birkeland »
