I'd like to add a low gain switch
hifitoaster · 5444
Offline hifitoaster
on: October 16, 2022, 02:59:31 PM
After the Crack, I was hooked. So build the S.E.X., it sounds awesome! I really like it with the LCD-X headphones (20 ohms, Sensitivity: 103 dB/1mW). However there's some hum with those headphones and I can BARELY turn the volume up from 0%.
I'd like some advice on how I could wire a low gain switch in the amp. Perhaps adding some resistors and a switch?
Thanks for the help!
Crack + Speedball -> Sennheiser 6XX
S.E.X. C4S
RME ADI-2 DAC FS, Denafrips Ares II -> Burson Soloist 3XP -> Audeze LCD-X (2021)
Offline ccmccull
Reply #1 on: October 16, 2022, 03:35:13 PM
I've done a couple of versions of this with PB's guidance
https://forum.bottlehead.com/index.php?topic=14385.msg130935#msg130935
I ended up using a switch but you don't have to. See the thread linked to from there to see the switchless version.
Colin. Insta @act4audio
Reply #2 on: October 17, 2022, 04:07:02 AM
Be sure that the nut near terminal 36 isn't touching terminal 36.  If those two touch, you'll get some hum.
Offline hifitoaster
Reply #3 on: October 17, 2022, 05:36:38 AM
Thank you Paul, I did check terminal 36, I even placed a bit of card stock paper between the nut and terminal 36 as an insulator. The funny thing is, I don't think I noticed a hum before the C4S upgrade. It seemed like the output was higher after the upgrade. Or maybe I did something wrong during the upgrade to introduce the hum.
S.E.X. C4S
Reply #4 on: October 17, 2022, 05:37:49 AM
If the volume control is all the way down, is the noise there?
Offline hifitoaster
Reply #5 on: October 17, 2022, 05:40:51 AM
Yes, still a subtle hum with the volume all the way down.
S.E.X. C4S
Reply #6 on: October 17, 2022, 05:42:23 AM
The padded output would be a good idea for your situation.
Offline hifitoaster
Reply #7 on: October 17, 2022, 05:45:28 AM
Thanks for the help Paul!
I'll order the parts to get a switched L-pad setup added. I'm going off the setup you helped ccmccull with.
S.E.X. C4S
