Wire Gauge Used In OP & PTs?
ZeusMC13 · 5889
Offline ZeusMC13
on: October 26, 2022, 04:40:04 AM
Which wire gauge sizes would  be used in the actual construction of  tube guitar amp push pull output transformers and power transformers?
Thanks.
« Last Edit: October 26, 2022, 04:42:31 AM by ZeusMC13 »
Reply #1 on: October 26, 2022, 05:18:42 AM
You really could find a super wide range of wire sizes in these parts, especially since you can wind multiple wires on the same winding at the same time, so if you need something like a 16 gauge wire size on a winding, you could opt instead to wind four 22 gauge wires at the same time instead to the same effect.
