Can anyone measure the value of an inductor?
Paully · 11575
Offline Paully
on: January 19, 2011, 11:24:35 AM
Grainger and I replaced the crossovers in my Altecs last weekend.  It was a truly dramatic change for the better, much more so than I even thought it could be.  Damping the horns didn't hurt either.  But of course there were no markings on the inductors.  I would like to find out how close they were to the stated value of 3.5mh on my schematic.  I can't be certain, from what I am told and have read, that the schematic really reflects what was in there and I would like to know.  So if I pay shipping there and back, is anyone willing to go to the trouble who has the tools to measure one or two?  Thanks.
Paul
Offline xcortes
Reply #1 on: January 19, 2011, 01:08:34 PM
Paul,
could you let us know what you ended up doing? I have a pair of 846As that may someday rebuild. It is encouraging that you improved them!
Xavier Cortes
Offline Paully
Reply #2 on: January 20, 2011, 12:02:58 PM
First I pulled the horns out and damped them with Dynamat xtreme.  It made a difference and was worth the money.  I think I paid $50 for 4 sheets but only used 2 that were 3 square feet each (plenty left over to damp my turntable).  Then we pulled out the crossovers.  I used a Russian PIO for the 4 mfd, didn't particularly care what I used for the 10.5.  I replaced the 3.5mh inductors with ones from PartsExpress.  On the advice of Zilch at the Lansing Heritage site I used an air gapped one for the high frequencies and an iron core for the low.  Instead of replacing the pot and resistor with better ones, also on the advice of Zilch, I used a 16 ohm L-pad to replace them both.  Anyway, to say I was pleased with the results would be an understatement.  And it was nice to have Grainger there who also seemed to be fairly stunned at how well things turned out as well.  I didn't think there was as much room for improvement as what I got.  Two concerns, I have only listened a few hours since, so you never know what I may come to feel in a month or so.  Second, some concern as to what the real value of the stock inductors is.  Also, keep in mind that some have said that you should replace the crossover with a model 19 crossover.  No idea, just mention it as something you could read up on.
Oh yea, I also replaced the fiberglass insulation with some acoustic eggshell stuff also from PartsExpress.  What difference that made I couldn't say because we did it at the same time as the crossovers.
Offline xcortes
Reply #3 on: January 20, 2011, 12:41:15 PM
Hi Paul,
It looks like my 846A will get a second chance. I think I'll need to buy an extra house to use them though!
Would it be much to ask about the inductors and L-pad part numbers?
And also, did you do something to brace the cabinets or improve the sealing?
Thanks again,
Xavier
Xavier Cortes
Offline Paully
Reply #4 on: January 20, 2011, 02:25:40 PM
I can't remember if the 846A was ever made in an 8 ohm version or if that was just the 846B but I am sure you will know what the impedance of your speakers is for the L-Pad.  Anyway, whether or not these are the best choices these are what I used!  Getting the L-Pad to fit was a chore.  We ended up drilling into a new spot in the wood with a fastener bit to wallow out an indent on the outside of the cabinet where the nut could sink down onto the shaft and then drilled out the rest of the hole and mounted the L-Pad on the inside.  Hard to describe.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=255-278
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=266-916
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-254
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-516
Didn't do any bracing or sealing.  I know that is recommended.  Maybe a project for another day.  The Acoustic Foam stuff I bought worked really well in terms of dimensions.  Easy to cut and the remnants I was able to use on the back of the speaker cabinet.  If you get around to this, do let me know how it works out for you and what you think.  It is an involved project.  Once I get them from Grainger I can forward on detailed photos of the crossovers to look at.
Offline RayP
Reply #5 on: January 21, 2011, 02:43:05 AM
A quick Google search will show a bunch of hits on measuring inductors. The link below is one of them. I don't have a decade resistance box and I presume you don't have one either. Since you are trying to confirm the 3.5 mh value, I would simply reverse the formula to calculate the value of the resistor and then see if that value resistor works in the circuit. At least it would be a starting point.
Of course, since the formula is dependent on frequency, this would be the inductance at 60 hz.
http://www.coilgun.info/theoryinductors/measureinductance.htm
ray
Ray Perry
Offline Paully
Reply #6 on: January 21, 2011, 03:21:47 AM
Just a thought, but couldn't one use a potentiometer in place of the Resistor box to get the equal voltage measurement then measure the resistance across the pot for use in the formula?
Reply #7 on: January 21, 2011, 03:29:03 AM
Paully is looking for someone who owns a device that will measure inductors who will measure it for him and ship it back to him.
On the Coilgun suggestion, I think Paully is right.  A pot wired to one outer leg and the wiper will suffice for a decade box.  You just have to measure it after getting a null rather than read it from a decade box.  The pot must not be inductive or you are in trouble.
But what really has me scratching my head is that this looks like it will only measure the series equivalent resistance not the reactive (inductive) component of the "Unknown" inductor.
This is somewhat of a "Bridge" to measure impedance (meaning, complex, AC and reactive).  I don't see how this method measures the reactive part of the unknown.
And maybe I'm wrong.  Maybe PJ will take a look?
« Last Edit: January 21, 2011, 03:31:54 AM by Grainger49 »
Offline elcraigo
Reply #8 on: January 21, 2011, 06:38:44 AM
Grainger,
The WT3 Woofer Tester will do it. I probably have another instrutment to do it - somewhere. You probably have my contact info. You can send it to me if you like.
So - how is that Seduction power supply?
Craig Lewis (elcraigo is a nickname a good friend who grew up in Mexico gave me)
Reply #9 on: January 21, 2011, 07:24:04 AM
Paul,
I have woofertester that El Greco just mentioned which reminded me that it can measure RLC values.  I'm in Colorado and will be glad to ddo it for you, but there may be somebody closer.
Thanks for the notes on your speaker rebuild -- sounds very much like what I plan to do for my Cornwalls, but also with the bracing and sealing -- may even flush mount the drivers if it looks possible.  Everything about these speaks is original and the only things that need work are the tweeter horns (which barely make 10 KHz now, the caps in the crossovers, and the seals on the midhorns.  That will be a summer project though.  Cabinet and grille are immaculate -- showroom condition.
Offline JC
Reply #10 on: January 21, 2011, 07:36:45 AM
I used to use something similar to this "Coil Gun" set up to measure the load on Constant Voltage Speaker lines.
IIRC, it used a 400 Hz Square Wave as a test signal, rather than the 6.3 VAC from a transformer, but the principle was the same.
And, yes, Paully, I expect a pot would do in place of the decade box, but I think you would want linear taper, and you may need more than one value to zero in on the null point.  IOW, keep reducing the pot impedance 'til you get the smallest value that will get you to the null point, since the smaller value will give you a more accurate reading across its range.
Jim C.
Offline Lee Hankins
Reply #11 on: January 21, 2011, 08:56:42 AM
I may not understand, but I have two inductance meters (one only inductance, and a multimeter with an inductance scale) that I have been using to measure chokes and crossover inductors for years, they sure seem to measure exactly or close to the values marked on each inductor or choke.  Is this not an accurate or proper way to measure chokes and inductors???
Cordially,
Lee Hankins
Lee Hankins
"End of the Road"
Homer, Alaska
Offline xcortes
Reply #12 on: January 21, 2011, 09:28:55 AM
Thanks for the parts links Paul.
And please do send me the crossover pics. I have a long list of projects but This one definitely made into that list!
Xavier Cortes
Offline JC
Reply #13 on: January 21, 2011, 09:49:06 AM
lth1, I would suspect the answer lies in how your meters arrive at their results.  But, the short answer is, IMO, if your meters are reading close to the known value of a part, they must be doing something right!  At least, within the range of values you are interested in.
Jim C.
Offline elcraigo
Reply #14 on: January 21, 2011, 10:43:39 AM
Man I just realized - I am a 'newbie' still after all these years (thanks Doc, I'm just kidding)
Hope all you's oldie's and er, well newbie's are doing well.
Time for a road trip Pauly and Grainger? It's only a 3 hour drive.
