News:
May 31, 2023, 07:27:21 PM
Author Topic: volume pot accuracy question  (Read 887 times)
Offline ccmccull
« on: November 05, 2022, 11:13:18 AM »
I've always had a ~20% left shift on my sex amp, which I have corrected using the balance pot on my moreplay. I finally decided to track down what was causing it, and it turns out it's the volume pot.
(1) The full resistance isn't the same on the left and right sides: 95.8kOhms on Right, 100kOhms on Left.
(2) The voltage divider implied by the pot is ~10% larger on the left side (i.e. 10% higher signal voltage passing through) for volume settings between full off and full on.
Is a 10% L/R voltage ratio inaccuracy typical for these volume pots?
Here are the full measurements (all taken without tubes inserted):
location 1                   location 2                         Pot setting*       ohms
input pin orange / R   input sleeve orange / R   9 o'clock   9.58E+04
input pin orange / R   input sleeve orange / R   12 o'clock   9.58E+04
input pin orange / R   input sleeve orange / R   3 o'clock   9.58E+04
input pin orange / R   input sleeve orange / R   7 o'clock   9.58E+04
input pin blue / L   input sleeve blue / L   9 o'clock   1.00E+05
input pin blue / L   input sleeve blue / L   12 o'clock   1.00E+05
input pin blue / L   input sleeve blue / L   3 o'clock   1.00E+05
input pin blue / L   input sleeve blue / L   7 o'clock   1.00E+05
input pin orange / R   R pin 8   9 o'clock   9.59E+04
input pin orange / R   R pin 8   12 o'clock   8.90E+04
input pin orange / R   R pin 8   3 o'clock   8.19E+04
input pin orange / R   R pin 8   7 o'clock   3.50E+00
input pin blue / L   L pin 8   9 o'clock   1.00E+05
input pin blue / L   L pin 8   12 o'clock   9.22E+04
input pin blue / L   L pin 8   3 o'clock   8.40E+04
input pin blue / L   L pin 8   7 o'clock   2.00E+00
*: the pot is installed so that 9 o'clock = no volume, 7 o'clock is full volume.
Colin
{Ortofon 2m Blue > U-Turn Orbit > Eros 2} & {Roon Ropieee RPi4 > hifiberry-digi2-pro > ANK DAC 2.1} > Moreplay > S.E.X. > {{Spendor_S3/5r2 & SVS_SB-1000 (x3)} & Grado_sr325x}
Re: volume pot accuracy question
« Reply #1 on: November 05, 2022, 01:10:59 PM »
Yes, the mistracking is common. That is why there is a balance control. But I'm not sure I grok a 20% left shift (what units?voltage? dB?) when you are showing a 4% difference in resistance of the left and right pot tracks. It might be easier to understand what is going on by injecting a known signal level into the preamp and measuring L vs. R output level with various knob positions. The difference in resistance can vary at different pot positions and that is why the adjustable balance control is used. The issue tends to be more noticeable at lower volume settings where the mistracking tends to be the worst.
The ultimate solution is to change to a much more expensive stereo stepped attenuator constructed with tight tolerance fixed resistors.
« Reply #2 on: November 06, 2022, 05:42:30 AM »
That's an inaccurate conclusion.  You could have a 50K track on one side and a 100K track on the other side and get perfectly accurate channel balance provided source impedance was sufficiently low.
If you wanted to measure the channel balance of your potentiometer, you could apply a 60Hz tone to the amp (it can be off for this) and measure the AC voltage (you will need a meter with a 2V AC scale) coming from the middle upper and middle lower lugs on the pot at various positions of the volume knob.  These values can be used to give you the difference in dB between channels at various positions.
Offline ccmccull
« Reply #3 on: November 06, 2022, 10:14:21 AM »
Thanks for your replies Doc & PB. First off, I want to make it clear that I'm not complaining about the L/R bias, it's entirely manageable by the moreplay balance setting. I was just curious what was causing it and had some time on my hands to dig in. I learned a bunch in the process. I hope the data I collected in the process are interesting / useful to someone.
Doc, the "20% left shift" was a perceptual shift - i.e. I perceive the center voice about 20% toward the left channel from center. On your suggestion, I'll get much more quantitative below.
Also, PB, I think I wasn't clear enough with how I was defining the 10% voltage divider bias I quoted. See the sheet I link below, "resistances" tab columns E & F for my definition. However, I also measured voltages as you suggested.
I've done a whole bunch of measurements throughout the audio signal path with my new oscilloscope. It's super interesting to see how each stage adds its own bias, some positive, some negative, and they all contribute to a total L/R bias on the speaker terminals. Here's all the data if you'd like to dig in yourself, but I'll give a summary below.
https://docs.google.com/spreadsheets/d/1FT5aIulK0keVEQmUIRlhREjrovQArGRNucm1jfJvB1g/edit?usp=sharing
Conclusions:
The pot adds 10% Vpp L/R bias for any setting below ~70% on. After the pot, the rest of the amp adds an additional 4-8% of L/R bias at 1000 hz and 5-10% at 15000 hz, and most of this additional L/R bias comes from the OTs. Setting the volume pot to full on provides the lowest overall L/R bias. Practically, these results are educational for me because I've never understood why I sometimes had to dial my balance pot off-center and other times I didn't. Now I understand that I should always run the sex amp at full volume to remove that source of variability and use the pre-amp for volume control.
Methods:
I used a function generator for sinusoidal test tones and dialed the input Vpp so that the output Vrms on the left speaker terminal was fixed regardless of the pot setting. I measured the Vmax, Vmin, Vpp, and Vrms on a Rigol ds1054z for all combinations of the following:
- test tones @ 1000 hz and 15000 hz
- input Vpp set to achieve L speaker output @ 1000 hz of 1.41 Vrms and 0.7 Vrms, separately. I re-adjusted the input Vpp for each pot setting. I also did one high output power test @ 3.6 Vrms
- measured 4 points in the signal path: from tube pin 10 through to the speaker outputs
- 4 pot settings: off (9 o'clock as I orient my pot), 12 o'clock, 3 o'clock, 5 o'clock, and full on.
Results:
- The Vpp L/R bias measured at pin 10 is similar to the voltage divider bias measured by pot resistance (see resistances tab): unbiased for pot at or above 5 o'clock, and +10% for 3 o'clock and below. As expected, this bias isn't frequency dependent.
- The first stage voltage amplifier adds < 1% of additional L/R bias at 1000 hz, and that's likely within measurement noise. At 15000 hz it adds 4-5% additional L/R bias, and as expected it isn't dependent on pot position
- The 2nd stage amplifier subtracts  ~ -5% Vpp L/R bias @ 1000 hz and ~ -3% @ 15000 hz
- The OTs add ~ +10 to +14% Vpp L/R bias @ 1000 hz. At 15000 hz it adds between 5% and 10%. Unexpectedly, these biases do seem to be pot dependent. (larger bias for lower pot settings)
- Overall, the Vpp L/R bias at the speaker terminals are between +4% up to +18% @1000 hz, depending on the pot setting. The L/R bias is slightly higher at 15000 hz, ranging between +5% and +21%. The lowest bias is at pot set to full volume, the highest bias is when the pot is set to 3 o'clock or lower.
- The total Vpp L/R bias at the speaker terminals is roughly the same for all the output powers tested. Even up to the 1.6 output watts I tested on the "higher voltages" tab, the L/R bias is similar.
Colin
« Reply #4 on: November 06, 2022, 10:49:15 AM »
A 10% difference is not quite 1dB, so audible but not substantial. If the output stabilizes at higher pot levels (which it often does), then you can pad down the pot.  See #3 here and the photo at the bottom of the first post. https://forum.bottlehead.com/index.php?topic=4295.0
