Eros Extra Real Estate
xcortes · 4291
Offline xcortes
on: January 19, 2011, 05:16:31 PM
I'm continuing with the design of my Front Panel Express chassis Eros. With PB's help I've settled on a horizontal layout in a big chassis. It looks like I'll have some available real estate for whatever you guys recommend!
SUTs have been taken care of. I've also thought of replacing the 270 ohm resistor on the PS with a C-7x choke. What other ideas can you come up with?
Xavier Cortes
Offline ssssly
Reply #1 on: January 20, 2011, 02:44:19 AM
If you have some extra space I would suggest motor run capacitors for the power supply and PIO for the rest. I would also suggest some Vishay "nakeds" for the input resistors while you are in there.
Offline Paully
Reply #2 on: January 20, 2011, 12:09:49 PM
Motor Run caps, now there is a cool idea.  Time to pull out the schematic and see what the values are.
