Bottlehead Kits
Eros Phono
Missing voltages [resolved]
olegreg
4462
olegreg
Jr. Member
November 21, 2022, 09:19:27 AM
I am doing post assembly tests. Resistances were fine.
DC volts at 1A & 1B fine
OA thru OkB all are 0 VDC
Whats up?
Greg
Last Edit: December 01, 2022, 02:20:54 PM by Paul Birkeland
Paul Birkeland
Global Moderator
Hero Member
Re: Missing voltages
Reply #1 on:
November 21, 2022, 12:56:18 PM
This is most likely a soldering issue on that front C4S board.
olegreg
Jr. Member
Reply #2 on:
November 28, 2022, 08:56:50 AM
You were correct, I found a couple bad solder joints on my 3rd inspection.
New issues on separate post.
olegreg
Jr. Member
Re: Missing voltages again
Reply #3 on:
December 01, 2022, 06:08:07 AM
I went to run the system this morning and no sound or anything from EROS 2. All VDC are good except OKA & OKB
which are at 0 VDC. It ran perfectly last evening.
I am at a loss...
Paul Birkeland
Global Moderator
Hero Member
Reply #4 on:
December 01, 2022, 06:12:38 AM
I would be looking at the shielded twisted pair wiring that feeds pins 4 and 5 on each of those sockets. That's about all the EF86s share between the two, and something like this is likely a flaky solder joint.
Doc B.
Administrator
Hero Member
Reply #5 on:
December 01, 2022, 08:50:28 AM
Maybe remove and reinsert the tubes too. Might clean some oxidation off and/or help to show where a weak joint on one of the tube socket terminals is.
olegreg
Jr. Member
Reply #6 on:
December 01, 2022, 02:09:21 PM
You guys nailed it! I re-flowed all the heater connections and yes, that did it.
Thank you, gentlemen.
Bottlehead Kits
Eros Phono
