Speedball OB Voltage 170V [resolved]
hodg68 · 2756
Offline hodg68
on: December 26, 2022, 01:28:40 PM
Hello all,
I'm currently building the crack + speedball kits and have run into a snag. I completed the crack system last night and it sounded great! Today I started on the speedball and ran into no issues until conducting the final voltage check. When the large board is connected to the terminal rails my voltages are as follows:
Large Board:
OA = 103.6
OB = 170V
B+ = 172.2
G = 0V
OB= 72.3V
Small Board:
OA = 171.6V
IA = 173.7V
B-A/B = 0V
IB = 173.7V
OB 72.3V
Additionally, the two LEDs that are closest to OA do not light up.
Before I connected the large board all my voltages and resistance values were within spec. Any suggestions would be really appreciated!
Best,
J.D.
« Last Edit: December 27, 2022, 07:07:40 PM by Paul Birkeland »
Reply #1 on: December 26, 2022, 01:37:25 PM
If you pull the 6080 and run the amp with just the 12AU7, does that resolve the voltage issue on the small board up front?
Offline hodg68
Reply #2 on: December 26, 2022, 01:51:08 PM
Hey Paul,
Thanks so much for your quick reply. Just removed the 6080 and the voltages on the small board are now (I think in spec):
OA = 74.5V
IA = 223V
IB = 223V
OB = 70.8V
Also, all of the LEDs on the small board are now lighting up.
Offline hodg68
Reply #3 on: December 26, 2022, 02:20:21 PM
Let me know if sending pictures of the build would help troubleshoot. I'm stumped. The 6080 tube worked great last night so I wouldn't think that the tube is bad.
Reply #4 on: December 26, 2022, 04:47:53 PM
It would be a good idea to post some build photos.
Offline hodg68
Reply #5 on: December 26, 2022, 05:29:11 PM
Attached are some picture of the build.
Reply #6 on: December 27, 2022, 05:21:59 AM
Everything that's not an LED on the big PC board needs substantially more heat from your soldering iron to be properly soldered.
Reply #7 on: December 27, 2022, 06:39:49 AM
Offline hodg68
Reply #8 on: December 27, 2022, 09:02:05 AM
Thank you Paul and Doc B! After going through and reheating both the large board and the small board on the speedball it works perfectly! My final voltages are:
Large Board:
OA = 107.9V
OB = 110.7V
B+ = 184.1V
G = 0V
Small Board:
OA = 75.3V
1A = 184.4V
B-A/B = 0V
1B = 184.4V
OB = 72.2V
The OA and OB on the Large Board are a little high but I read on some other posts that these numbers can come down after wearing in the tubes. Here are some completed pictures! It sounds amazing through my Yamaha MusicCast WXC-50 and Sennheiser 800S.
Thanks again for your help!
Reply #9 on: December 27, 2022, 11:59:13 AM
Well done!
Reply #10 on: December 28, 2022, 03:54:53 AM
Nice finish all around, glad you got it sorted.
