Driver Testing error (RESOLVED)
Urbansandz · 30758
Reply #15 on: February 01, 2023, 05:44:37 AM
OK, so that tells us that the zener string is installed and working properly, and that the A side of the C4S appears to be working properly.
Some things I would check are:
1.  Does this happen with all 5670s?
2.  Are the red wires leaving OA and OB going to the correct places?
3.  What is the Kreg voltage on the B side of the board with the issue?
Offline Urbansandz
Reply #16 on: February 01, 2023, 09:41:52 AM
Thank you Paul.
1. Yes, issue persists after switching tubes.
2. OA goes to +reg B, and OB goes to 46U
3. B Kreg = 1.8 VDC. On the A side board it's 7.36, so that must be where the problem lies, though I don't know how to remedy. Replace the TL431 on the B side?
Reply #17 on: February 01, 2023, 10:17:12 AM
Yes, I would put a new 431 in on that side.
Offline Urbansandz
Reply #18 on: February 01, 2023, 03:52:50 PM
I replaced the 431 on the B side, but no luck. I'm still getting ~145 VDC on OA and 1.8 VDC on Kreg(B).
Reply #19 on: February 01, 2023, 04:23:16 PM
What's the DC voltage at the random pad marked with the "X" on the B side?
Offline Urbansandz
Reply #20 on: February 01, 2023, 05:19:22 PM
The x on the B side is measuring 2.65 VDC.
Reply #21 on: February 01, 2023, 06:03:55 PM
How about bB?
Offline Urbansandz
Reply #22 on: February 01, 2023, 06:56:34 PM
OK, yeah, there's a problem there. I'm getting ~72 VDC at bB.
Reply #23 on: February 02, 2023, 04:19:06 AM
Can you verify that the R1 resistor values are in the correct spots?
Offline Urbansandz
Reply #24 on: February 02, 2023, 05:30:30 AM
R1(B) is measuring at 215 Ohms.
Reply #25 on: February 02, 2023, 05:44:12 AM
At this point it would be super helpful to trade the PC boards between sides.  If the OA voltage stays on the same socket, then we need to figure out what's going on with the socket wiring itself.  If the OA voltage moves with the board, then there's something wrong with the PC board population/jumpering that just hasn't been noticed yet.
Offline Urbansandz
Reply #26 on: February 02, 2023, 07:19:10 PM
I switched the boards and the issue remained with the board. The OA was still 145 VDC on the board that was previously on the D side and now moved to the A side. I've attached photos of the two boards. The problem board is on the left in both photos.
Offline debk
Reply #27 on: February 03, 2023, 01:44:44 AM
Hard to tell from picture, but the black wire going from bA to -reg has a long bare area at bA.  Could this be touching one of the pads on the pot especially when the wires are compressed when attaching the board?
It's a long shot
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Reply #28 on: February 03, 2023, 04:18:09 AM
I would set your meter to continuity beep and be sure none of the legs of Q1 on the A side of the funky board are touching.  It's possible you may have a teeny tiny solder bridge causing problems there.
Reply #29 on: February 03, 2023, 08:01:26 AM
Underside pic - right hand board - looks like a cold joint on a 431 pad. The row of pads above IB, fifth pad in from right.
Topside pic - left hand board - possibly a cold/missed connection at the bA pads next to the blue trimpot. Though it seems to look OK on the underside. I'd reheat just to be sure.
