Bottlehead Kits
Eros Phono
One side no power
One side no power
raymonyng
4895
raymonyng
Jr. Member
One side no power
January 01, 2023, 04:45:12 AM
Hi, I am a new guy. My eros2 after I welding and found out B side no power, A side have power, but the led didn’t light, the D1 l check there’s no voltage, and D6 have 247V, what can I do, please help.
Paul Birkeland
Global Moderator
Hero Member
Re: One side no power
Reply #1 on:
January 01, 2023, 05:24:54 AM
What are the IA, IB, OA, OB, KregA, and KregB voltages on the board above the D socket?
What are the voltages at IA, IB, OA, OB, OC, OD, OKA, OKB, OKC, and OKD on the forward board?
raymonyng
Jr. Member
Reply #2 on:
January 01, 2023, 10:53:38 AM
Hi, thanks for help,
IA. 346V
IB. 347V
OA. 345V
OB. 0V
OKA. 30V
OKB. 0V
IA. 0V
IB. 329V
OA. 0V
OB. 0V
OC. 0V
OD. 0V
OKA. 0V
OKB. 0V
OKC. 0V
OKD. 0V
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
January 01, 2023, 11:34:58 AM
There's no OKA and OKB on the board above the D socket.
raymonyng
Jr. Member
Reply #4 on:
January 01, 2023, 11:46:49 AM
Terminal check only the left output head is 46K not the 470K, see what’s wrong. Thanks.
Sorry, about the D Socket that’s Kreg A and Kreg B, not the OKA and OKB. you are right.
Paul Birkeland
Global Moderator
Hero Member
Reply #5 on:
January 01, 2023, 11:48:16 AM
Swapping those resistors won't cause the voltages to drop. Remove the wires from IA and IB on the front board and let them poke up into the air, then recheck the voltages on the board above the D socket.
raymonyng
Jr. Member
Reply #6 on:
January 01, 2023, 12:28:00 PM
I disconnect the IB from IA then the voltage are:
IA. 332V
IB. 0V
OA. 0V
OB. 0V
Kreg A. 29V
Kreg B. 0V
Paul Birkeland
Global Moderator
Hero Member
Reply #7 on:
January 01, 2023, 12:49:08 PM
IA and IB are connected with a piece of wire. Since your IA and IB are not the same, that wire is missing or broken.
The 29V at KregA will happen if one of the little resistors that goes to pins 2/7 on the D socket isn't well connected, or it's also possible one of the black wires back there is loose.
Bottlehead Kits
Eros Phono
One side no power
