Resistance Check oddities
snm · 5545
Offline snm
Reply #15 on: February 06, 2023, 06:00:55 AM
I have to order some replacements as I cut the leads and originally installed them pretty close to the terminal strip. I'll report back as soon as I get some replacements put in :)
Offline snm
Reply #16 on: February 07, 2023, 06:09:04 AM
Ok, with resistors reinstalled:
Terminal 1: ~67-68V
Terminal 2: 229V
Terminal 3: 0V
Terminal 4: 229V
Terminal 5: 83V
This is without the tube installed
With the tube reinstalled, my readings are:
Terminal 1: 57.6V
Terminal 2: 179.2V
Terminal 3: 0V
Terminal 4: 179.1V
Terminal 5: 71.1V
« Last Edit: February 07, 2023, 06:43:24 AM by snm »
Reply #17 on: February 07, 2023, 08:56:38 AM
Can you carefully measure the voltage at A8?
The 67V seems pretty low, but you could have a 12AU7 with one half that's very potent, or there could be another issue at work.
Offline snm
Reply #18 on: February 07, 2023, 09:00:34 AM
A8 looks to measure out to 1.595V (with both tubes plugged in)
Reply #19 on: February 07, 2023, 09:03:41 AM
How about A3?
Is the jumper installed on the volume pot between the lugs where black wires land?
Offline snm
Reply #20 on: February 07, 2023, 09:10:17 AM
I’m reading 1.588V at A3.
Can you clarify what you mean by the jumper?
Reply #21 on: February 07, 2023, 09:46:12 AM
There should be a bare wire between the upper and lower lugs on the volume pot where the black wires connect.
Offline snm
Reply #22 on: February 07, 2023, 10:03:45 AM
Oh, my apologies. That's installed. Here's a picture for reference:
https://drive.google.com/file/d/1DkNyuo6HC6RzHT0YkimH5LeOLhx0bzWh/view?usp=sharing
Reply #23 on: February 07, 2023, 12:45:11 PM
Does the amp otherwise sound good and work in what would be considered a normal way under these conditions?  Can you post some photos of the 12AU7 you have as well?
Reply #25 on: February 07, 2023, 01:31:00 PM
I would pop the PC board back in and give the amp a listen.  It may just be that your 12AU7 is unusually potent.
Offline snm
Reply #26 on: February 07, 2023, 01:32:59 PM
Am I fine to listen with the small board only? I haven’t proceeded past testing voltages yet, but wanted to confirm first. Appreciate your help with this!
Reply #27 on: February 07, 2023, 01:54:43 PM
Yes, the amp will work with just the small PC board installed provided the 3K/10W resistors are still present.
Offline snm
Reply #28 on: February 10, 2023, 09:11:56 AM
I've been running the stock Crack for a few days now, without the small board just to see if any issues arise. Only thing I have a question about is the TRS connector. After listening for about ~30 minutes today, I unplugged my headphones and noticed the TRS connector was slightly warm. I assume this is normal?
Reply #29 on: February 10, 2023, 09:19:11 AM
Sure, the whole chassis will be warm after playing for a while. The Brits call vacuum tubes thermionic valves. Emphasis on the 'therm' syllable here. Tubes only work if their heaters are hot, and of course that heat energy transfers into the rest of the amp. The power transformer also gets quite warm.
