Resistance Check oddities
snm · 5555
Offline snm
on: February 02, 2023, 07:27:25 AM
Hello, first timer here. I'm at the stage where I'm measuring resistance and while most of my measurements are in the expected values, there are a few terminals where the resistance checks are a little off. I was hoping somebody might be able to tell me what I should look for to troubleshoot the differing values.
TerminalExpectedMeasured
1*22.39K Ohm
2*269 Ohm
4*269 Ohm
5*22.38K Ohm
13*269 Ohm
200 Ohms-0L
Reply #1 on: February 02, 2023, 07:50:11 AM
I would recommend posting some build photos.
The lack of a solid 0 ohm reading on 20 tells me that you have a black wire that's poorly soldered somewhere.  Often the junction of the two black wires on the headphone jack is not well soldered, but I suspect it would help to redo all of the joints where black wires land.
Are you sure the DC resistance reading on 2 and 4 is not 269K?
Expect at least a blown fuse on power-up, if not smoke, so let's resolve these before powering up.
« Last Edit: February 02, 2023, 08:16:47 AM by Paul Birkeland »
Reply #2 on: February 02, 2023, 07:56:26 AM
If the reading is actually 269 ohms that value tends to indicate a possible miswire, as that reading seems to imply that the big white 270 ohm resistor is grounded at one end when it should not be. You might want to post pics of the wiring of the terminal strips on either side of the power transformer and chack closely where all the black wires have been attached.
Offline snm
Reply #3 on: February 04, 2023, 08:16:24 AM
Appreciate the help. I went through all my wiring and noticed I did indeed miswire the black wire on 12U to 15U by mistake :/ Corrected it and rewired it to 14U as instructed.
My resistances seem to match what’s expected but I think i need some clarity around the terminals with an asterisk. I know the docs state to watch out for 0 readings at those terminals as they would indicate something is wrong, which luckily none of mine are showing as 0. However, I do see these readings around 1.5M to 1.6M while steadily dropping. Is this normal?
Reply #4 on: February 04, 2023, 05:24:47 PM
That that's millions of ohms, which is sufficiently far away from 0 to not be concerned.
If you saw something like 5 ohms, then that would be concerning.
Offline snm
Reply #5 on: February 04, 2023, 05:46:40 PM
Awesome, thanks! Tested it today after checking voltages and what a great treat it was!
I've moved to the speedball and when measuring my voltages, 0A measures out to 44V pretty consistently, while 0B measures out to 60V.
IA and IB are both about 177V and B-A/B is 0V.
I redid 0A just to be sure and it's still measuring out to 44V. Since this is below the 60-90V range I'm hesitant to move forward. Any thoughts?
I should note that my tubes still glow just fine and the LEDs are lighting up without apparent issue.
« Last Edit: February 04, 2023, 09:04:40 PM by snm »
Reply #6 on: February 05, 2023, 06:05:20 AM
How were the voltages without the Speedball?  We absolutely recommend using the amp for a week or two in its stock configuration before moving onto the Speedball.
Your OA and OB are very low.  We have seen that from a backwards Q1 transistor and from soldering issues.
Reply #8 on: February 05, 2023, 09:32:03 AM
Can you tell me about the solder and soldering iron you're using?  That looks like it could potentially be an iron that isn't hot enough at work here, or oddball solder.
Offline snm
Reply #9 on: February 05, 2023, 10:19:12 AM
Sure, I’m using a Hakko FX-951 and some Cardas Soldering Wire Quad Eutectic Silver Solder with rosin flux
Reply #10 on: February 05, 2023, 10:52:02 AM
I would turn the iron up to the maximum temperature if you haven't already.
Offline snm
Reply #11 on: February 05, 2023, 12:22:15 PM
So, I reflowed the components on the small board at max temperature and still get around the same readings. I also checked voltages at B1 and A6 and they both come out to around ~45V, though I’m obviously no electrician and not sure if that measurement even matters/makes sense :)
To rule things out I’ve rewired A6 to 1U redid the small white wire from 1U to OA but the measurements are still the same.
Also, for what it's worth, my 8 pin tube doesn't sit all the way flush with the socket, seems its a bit tight but I don't know if that matters, figured I'd mention it anyways in case it was applicable in troubleshooting.
« Last Edit: February 05, 2023, 12:27:55 PM by snm »
Reply #12 on: February 05, 2023, 01:40:07 PM
Do those voltages change if you pull the 6080 and run the amp with just the 12AU7?
Offline snm
Reply #13 on: February 05, 2023, 01:45:52 PM
No, they appear consistent. IA and IB go to 223V, up from 177V before.
Reply #14 on: February 06, 2023, 04:13:05 AM
Can you remove that PC board and temporarily reinstall the 22.1K resistors and recheck the voltages at terminals 1 and 5?
