New Moreplay build complete, sounds great
timindq · 4864
Offline timindq
on: February 10, 2023, 07:16:50 AM
It's been a few years since I've built a Bottlehead kit, and this one was a great way to get back into kit building. After finishing I successfully completed the resistance checks with no problems. Unfortunately, when I hooked the Moreplay up to an amp to test with music, there was no sound from the left channel. After checking all of the obvious possible missteps with connections, I turned the unit over for more serious troubleshooting. It took a few minutes of signal tracing to find I had reversed the left channel leads coming from the Input Select switch. Swapping the wires was no problem, whew.
Hooked the amp back up, and two-channel music was happening. I installed the Moreplay into my stereo last night and sat back for some fantastic sound. Thanks Bottlehead!!!
Source: Lumin D2 with SBooster power supply, 2tb SSD attached to Lumin, Pre: Moreplay, Amp: Bryston 2bSST, Speakers: Joseph Audio RM22XL. Setup in large, well treated dedicated listening space.
Reply #1 on: February 10, 2023, 07:23:39 AM
Thanks, and congrats on the completion!
Reply #2 on: February 10, 2023, 07:27:40 AM
Excellent work tracking down the wire swap!
Offline timindq
Reply #3 on: February 10, 2023, 07:29:22 AM
And I didn't have to bug you guys! ;)
Reply #4 on: February 10, 2023, 07:30:25 AM
More opportunities will undoubtedly arise in the future  :)
