snm · 2288
Additionally, XLR to RCA cables or converters commonly have XLR pin 3shorted to ground, which will overload the dac8 PRO’s output stage and may even be causeto damage after long-term use with high signal levels. In case you need to interface thedac8 PRO to an amplifier with single-ended inputs only, please use cables without the short,like “Benchmark XLRF to RCA adapter cable for analog audio – pin 3 floatingâ€.
