follow the noise.
robertod · 3482
Offline robertod
on: February 17, 2023, 06:05:30 AM
I have monoblocks, when i turn on my system, there is a crackle noise coming out of the left speaker. I upgraded some caps and resistors about 8 months ago and everything worked no crackle).
I removed the monoblock from system and check solder.  I noticed one connection was loose on a resistor. I re soldered the resistor, turned on system noise gone, so I thought.
Next day turned on system a slight crackle noise out of speaker again. (sounds Muffled).  I checked all solder joints they looked good. (re soldered a few that looked suspicious) crackle noise still there.
Today I moved monoblocks, Left one to the right and right to the left.  The noise followed the monoblock.
What else should I check for?  Thanks for your help and recommendations.
Rega P6
George Wright Sound WPL20 preamp with phono
George Wright Sound 2A3 Mono Blocks 3.5 watts
Audio Note M-1 Phono Pre-Amplifier
Jager Speakers
Online Paul Birkeland
Reply #1 on: February 17, 2023, 06:13:25 AM
Swap the tubes.  Also keep in mind that any solder joint in the amp could cause a noise like this, not necessarily what is associated with the recent mods.
Offline robertod
Reply #2 on: February 17, 2023, 06:21:15 AM
Thanks for the reply.  I will swap tubes once system cools down.
Rega P6
Jager Speakers
Offline robertod
Reply #3 on: February 17, 2023, 07:22:28 AM
I could only swap tubes from one mono block to the other.  There was no crackle noise out of right or left speakers.  I'm wondering if the tubes were not seated correctly.
The 2A3's are 2 years old.
The 5y3's are 2+ years old.
The 6sn7's are 2+ years old.
Rega P6
Jager Speakers
Reply #4 on: February 18, 2023, 09:08:54 AM
It could just be a little pin oxidation.
Offline robertod
Reply #5 on: February 19, 2023, 05:30:17 AM
PB, thanks for your replay. Time to clean pins.  The tubes should be good for awhile or should I consider replacing the rectifier tube.
Last night all good no crackle and music sounds good.
Thanks again.
Rega P6
Jager Speakers
Offline robertod
Reply #6 on: February 25, 2023, 05:24:32 AM
Could a tube or tubes cause the crackle noise?
Rega P6
Jager Speakers
Reply #7 on: February 25, 2023, 07:31:05 AM
If the crackling noise is related to a specific tube, then the noise will follow that tube if you swap it to the other channel.
Offline robertod
Reply #8 on: February 25, 2023, 11:39:38 AM
okay thanks, I will do that this evening.
Rega P6
Jager Speakers
Offline robertod
Reply #9 on: February 25, 2023, 12:37:27 PM
moved the tubes to the right monoblock and noise followed.
Rega P6
Jager Speakers
Reply #10 on: February 26, 2023, 06:05:15 AM
If you move them one at a time, you may be able determine which one is crackling.
Offline robertod
Reply #11 on: February 27, 2023, 04:22:52 AM
I moved one and no noise.  It is the 5y3(rectifier).  I'm glad it was just the one tube.
Rega P6
Jager Speakers
