re faulty crack [resolved]
ross munro · 2322
Offline ross munro
on: March 01, 2023, 11:51:15 PM
hi i have been using my crack for 2 years now and it has operated seemlessly however when i switched it on last night the volume was at maximum and heavily distorted,the volume control did not adjust it at all when i touched the top of the 12au7 valve everything returned to normal volume and the volume was working again this worked for about 5 minutes then the volume increased again to maximum and i had no control over it .it is now permanently at this extreme volume and heavily distorted.unfortunately due to my brain disease i can no longer solder or do checks on the unit due to extreme hand shaking. im based in the uk does anyone know of a good repair centre that could repair this for me as the 3 firms ive contacted so far wont touch it.is it possible the 12au7 valve is faulty7 although it lights up as normal.hoping you can help
regards mike haywood
« Last Edit: March 02, 2023, 03:06:07 PM by Paul Birkeland »
Reply #1 on: March 02, 2023, 04:37:41 AM
Does the volume go to full on both channels or just one channel?
This is a loose wire, definitely not a bad tube.
Offline ross munro
Reply #2 on: March 02, 2023, 06:09:21 AM
its on both channels extremely loud
Reply #3 on: March 02, 2023, 06:10:28 AM
The black wire between the RCA jacks and volume pot is probably not connected well on one end, or possibly one of the other black wires attached to the pot.
Offline ross munro
Reply #4 on: March 02, 2023, 06:19:45 AM
ok thanks paul i will very carefully re flow that wire many thanks for getting back to me so soon.i will let you know how it goes have a good day. speak soon
Offline ross munro
Reply #5 on: March 02, 2023, 11:52:07 AM
 :) ah sweet music once again thanks so much paul,you were right managed to re solder joint at volume pot and hey presto everything is good.im not sure if you know but a group of valve enthusiasts in the uk have obtained the original valve making machines and are producing new brimar valves to a very high standard including 300b,12au7 and many others the website is THE GREAT BRITISH VALVE PROJECT  i hope this is useful to you and doc b. once again thanks for the advice on how to fix my crack
