Failed Final Voltage Check
Dhouse7516 · 53592
Reply #30 on: April 12, 2023, 10:39:44 AM
A broken wire could cause some issues, though one wire is unlikely to cause all of what you're seeing.
Offline Dhouse7516
Reply #31 on: April 12, 2023, 12:15:20 PM
Okay, thanks. I am at a loss. I went back over the board and the tube terminals again, re-flowed a couple of additional joints, replaced the shunt board wires and am still getting very similar readings:
IA: 284
IB: 285
OA: 280
OB: 152
KREG A: 6.38
KREG B: .45
Unless you have any additional thoughts, I will reach out to the address you provided earlier and request a repair. Please keep me in the loop as I really want to know what the issue is here and learn from this! Thanks for all of your help.
Offline Dhouse7516
Reply #32 on: April 12, 2023, 12:52:03 PM
Paul, as I was going back over the board just now, I noticed that the R3 resistor on the B side has a large crack in the end. I tested it and it's bad (no resistance). If you think that this might explain the issues I'm having, I'll order another one and replace before sending in for repair. Thanks.
Reply #33 on: April 12, 2023, 07:38:03 PM
It certainly wouldn't hurt to give that a try.
Offline Dhouse7516
Reply #34 on: April 13, 2023, 05:37:25 AM
Reply #35 on: April 13, 2023, 05:56:32 AM
Sure, that will work nicely.
Offline Dhouse7516
Reply #36 on: April 13, 2023, 06:34:08 AM
Thanks, Paul. I need to order some additional single-core wire as well. It’s 26awg, correct?
Reply #37 on: April 13, 2023, 06:37:56 AM
22 AWG solid is recommended.  The kit should have come with some extra wire.
Offline Dhouse7516
Reply #38 on: April 13, 2023, 06:55:31 AM
Thanks, I used up the extra when I was re-wiring the D socket and the board
Offline Dhouse7516
Reply #39 on: April 20, 2023, 12:56:58 PM
I received the replacement R3 resistor today that we discussed above. It's physically smaller than the one supplied with the kit (see picture). I assume that's because it has a different tolerance or wattage. Maybe a dumb question, but do I need to be concerned about this? Do I need to replace the A side R3 with a matching resistor (I bought two) as well as the B side, which is the one that is damaged? Thanks.
Reply #40 on: April 20, 2023, 01:07:06 PM
Just replace the one that needs to be replaced. They function indentically.
Offline Dhouse7516
Reply #41 on: April 20, 2023, 01:21:05 PM
Excellent. Thanks, and will do.
Offline Dhouse7516
Reply #42 on: April 20, 2023, 04:08:10 PM
So this is strange. I tested the new resistor before installing and it passed at 2.49k ohms. After I installed and soldered it to the board, the resistance check at the leads (on both sides of the board) is failing. I’m getting readings of 10-11 ohms (not K ohms). When I test the R3 on the A side at the leads I am getting 2.49k ohms. Does this suggest any obvious issues to you?
Offline Dhouse7516
Reply #43 on: April 20, 2023, 05:38:34 PM
The most obvious issue to me is that I might suck at soldering PCB boards.
Reply #44 on: April 21, 2023, 05:17:33 AM
That would most likely be a shorted 431 regulator.
