Swapping power tubes on Crack has whine in right channel
computerman · 2367
Offline computerman
I have built a Bottlehead Crack with Speedball.
When I use the GE 6080 that shipped with it, it works flawlessly.
I bought an RCA 6AS7G from tubedepot.com and it looked clean; the box certainly wasn't. This is supposedly a "known to work" from the tube-rolling forum.https://forum.bottlehead.com/index.php?topic=663.0.
I get a whine only in the right-channel when I use this tube. I've reseated it a few times to no avail. I roll back to the GE and the whine goes away.
This whine is not affected by volume levels.
Is this a bad tube, or is it "just so much better" than the GE that it is showing a bad solder joint, and therefore I should reflow all my connections?
  • Passed all resistance/voltage checks
  • Tube has been baking in for likely 48 hours of on-time
« Last Edit: April 05, 2023, 09:42:43 AM by computerman »
Offline Thermioniclife
Reply #1 on: April 05, 2023, 10:42:10 AM
Sounds lika a bad tube. but it shouldn't hurt to leave it on for a few more days.If still no good try to get your money back.
Reply #2 on: April 05, 2023, 07:01:32 PM
Try cleaning the pins.
