The last question
raymonyng · 5093
Offline raymonyng
on: May 15, 2023, 11:01:41 AM
Hi, after few months, finally came the this situation. The A side voltage is correct, it’s 215V. 165V  105V. 98V. 1.837V, and the B side is not correct, it 215V. 145V.  141V. 141V. 0.002. Then I flipped over the board and now A side is become B side and B side become A side. This time the B side became to A side is correct, and the A side becomes B side is not correct. That means the welding in both sides re correct. But what’s makes them reading the same when I flipped over the board. Thanks for help.
Reply #1 on: May 15, 2023, 11:21:52 AM
It looks like the EF86 in the B socket is not conducting. Easiest place to start is swap the EF86 tubes and see if the problem follows when you move the B side tube to the A socket. If it doesn't follow thw tube there might be a bad connection at socket pin B3.
Offline raymonyng
Reply #2 on: May 16, 2023, 10:00:31 AM
Hi, thanks for your advice, it’s because of the EF86 the voltage is not correct, so can your company exchange the tube for me? Thanks very much.
Reply #3 on: May 16, 2023, 10:06:02 AM
Yes, contact Eileen at [email protected] and she can send you a replacement EF86.
Offline raymonyng
Reply #4 on: May 17, 2023, 01:13:41 AM
Thanks for all, it’s nice sound.
