6J5 to 6C45P?
currly30 · 9436
Offline currly30
on: May 17, 2023, 08:10:54 PM
Would I be able to use the 6J5 tubes with an adapter in place of the 6C45P?
Reply #1 on: May 17, 2023, 08:39:08 PM
Most definitely not a good idea!
Offline currly30
Reply #2 on: May 17, 2023, 09:43:22 PM
Why is that? Doesn't it have the same voltage and current?
« Last Edit: May 17, 2023, 09:53:11 PM by currly30 »
Online Doc B.
Reply #3 on: May 18, 2023, 04:17:21 AM
Very different tube with much less gain, much less max plate dissipation  and much higher output impedance. The most feasible substitute for a 6C45pi is a WE437A. IME the 6C45pi sounds just as good as the 437A and even a bit better in some applications.
Reply #4 on: May 18, 2023, 04:37:51 AM
You'd also be running at nearly maximum cathode current, which would also likely shorten the lifetime of a 6J5.
Offline currly30
Reply #5 on: May 18, 2023, 10:56:23 AM
Interesting. Thank you for the information.
Offline bergurbrag
Reply #6 on: July 17, 2023, 06:00:55 AM
Hi ! Are there any upgrade tubes for the Mainline you would recomend, that would upgrade the sound ?
Online Doc B.
Reply #7 on: July 17, 2023, 06:09:57 AM
The most feasible substitute for a 6C45pi is a WE437A. Of course this requires completely different sockets and the tubes are very expensive. IME the 6C45pi sounds just as good as the 437A and even a bit better in some applications.
IMO the energy would be better spent upgrading headphones or maybe playing with boutique capacitors.
Offline ipetruk
  • Igor Petruk
Reply #8 on: August 23, 2023, 10:36:27 PM
Also 6S15p, I tried it. Sounds different, a matter of taste
Crack, Mainline, Pipettes, Subette
