Oh NO! Left channel down! [resolved]
Ivan303 · 66202
Offline Ivan303
on: June 06, 2023, 10:09:16 AM
OK, tubes light, swap with right channel tubes, still no sound from left channel (thankfully not one of the EML 2A3s which are REALLY expensive).
Where to start?
Near 400V B+ on the 300B.
2 LEDs light up on the B side but no LED lights on the A side of the regulator board.
About 100+ V on each of the heat sinks of the two MJE5731.
This after working perfectly for near to a year.
Sudden, not intermittent.
Maybe not something I did(for a change), as have not messed with these guys for nearly a year.
Guessing one of the solid state parts on the board?
Thoughts?
Thanks.
« Last Edit: June 10, 2023, 05:10:28 AM by Paul Birkeland »
Reply #1 on: June 06, 2023, 10:13:44 AM
Can you post the voltages on all four pins of the 4 pin socket? (which hopefully has a 2A3 plugged in, not a 300B).
Also measure and post:
IA, OA, IB, OB, KregA, KregB on the driver board.
Offline Ivan303
Reply #2 on: June 06, 2023, 10:32:42 AM
Type-o
Tube is a 2A3EH GOLD!
61.9V
64.3V
382.0V
14.5 mV
Reply #3 on: June 06, 2023, 10:57:32 AM
OK, the 4 pin voltages are fine.  How about the ones on the driver board?
Offline Ivan303
Reply #4 on: June 06, 2023, 10:59:15 AM
AND...
IA   409V
OA  111V
IB  111V
OB 111V
KReg A  2.71V
KReg B 109V
Reply #5 on: June 06, 2023, 11:00:03 AM
Remove the 5670 and recheck those voltages.
Offline Ivan303
Reply #6 on: June 06, 2023, 11:10:21 AM
IA  419V
OA  419V
IB 418V
OB 417V
KREGA 0V
KRegB 416V
Reply #7 on: June 06, 2023, 11:25:26 AM
There is nothing on the board that should have KregB shooting up that high, and having no tube in the socket rules out a badly shorted tube.  Some adjacent terminals somewhere on the PC board or tube socket are touching that shouldn't be, and this is causing the super high voltage at KregB, or possibly the black wire from bA to -Reg B on the B side is broken and not providing a ground reference for the regulator.
You will need to remedy the issue causing the high voltage at KRegB, then it's 50/50 that the TL431 on the B side of that board will need to be replaced.
Offline Ivan303
Reply #8 on: June 06, 2023, 11:31:34 AM
Keeping in mind that KReg B is 109V with a tube in the socket?
Will try to figure out where there may be a short?
With the tube out of the socket, is it possible for the pins of the socket shorting to each other?
Offline Ivan303
Reply #9 on: June 06, 2023, 11:43:04 AM
And, of course, I was reading Reg B at 416V, not KReg B as instructed.
KReg B is also OV with the tube removed.
Sorry.
Offline Ivan303
Reply #10 on: June 06, 2023, 11:46:27 AM
And...
KReg B with the tube installed is about 5.6V
Sorry
Reply #11 on: June 06, 2023, 01:37:36 PM
Slip the wire out of OB and leave it poking up into the air, then recheck IB and KregB.
Offline Ivan303
Reply #12 on: June 06, 2023, 02:05:54 PM
Wire to OB removed.
Tube out
IB 412
KReg B 0V
Tube in
IB 116
KReg B 6mV
Reply #13 on: June 06, 2023, 02:09:32 PM
What voltage do you see on the X pad on the B side? It's next to bB.
If you could post pictures of the top and bottom of the driver board, as well as the 9 pin socket wiring, there may be something we can see.
Offline Ivan303
Reply #14 on: June 06, 2023, 02:12:56 PM
Tube in or tube out?
