Voltage check problem [resolved]
Hazim_hatta · 7929
Reply #15 on: July 08, 2023, 06:10:14 AM
I see a 22 ohm resistor in your power supply that is the wrong value.  Putting the correct parts in here will fix the high B+ issue that you had before and drop the noise floor down closer to where it should be (which will further be lowered by twisting the green wires and dealing with the unbraided input wiring).
« Last Edit: July 08, 2023, 06:22:04 AM by Paul Birkeland »
Reply #16 on: July 08, 2023, 06:35:46 AM
Did you receive that 22 ohm resistor in your kit? If so we may have sent the wrong part and we will replace it. Please check the value of the other large white resistor too.
Offline Hazim_hatta
Reply #17 on: July 08, 2023, 02:52:05 PM
Yes, I received it in my kit. And I'm not checking it before.
Offline Hazim_hatta
Reply #18 on: July 08, 2023, 08:18:45 PM
how about LED not lights up suddenly?
Reply #19 on: July 09, 2023, 04:48:18 AM
LEDs not lighting up suddenly will mean that the DC voltages on terminals 1-10 are no longer correct and you would want to post those numbers in order for us to help you determine what has gone wrong.
You will definitely want to get some 270 ohm 5W resistors in there, feel free to drop an e-mail to replacementparts(at)bottlehead(dot)com and we can get some sent to you.
Offline Hazim_hatta
Reply #20 on: August 11, 2023, 08:57:39 PM
Just have time to rework on the crack, everything works perfectly, thank you all
