Bottlehead Kits
Stereomour II
Limitation on 2a3 tubes
DPetrini
6575
DPetrini
Jr. Member
July 08, 2023, 09:29:46 PM
Hi all, can the stereomour II use all types of 2a3 like RCA grey or black plates ?Just to be sure before try.thanxs
Daniel
Good hand at solder , badhead in electronics
Paul Birkeland
Global Moderator
Hero Member
Re: Limitation on 2a3 tubes
Reply #1 on:
July 09, 2023, 04:46:28 AM
Yes.
Tom-s
Sr. Member
Reply #2 on:
July 09, 2023, 06:55:36 AM
Should be mentioned that early 1935-1936 "monoplate" 2A3 can be used in Stereomour and I wouldn't recommend using them in a stock SII. I wanted I'd recommend dropping the B+ voltage/limit the cathode dissipation and use a slow heater start up for longevity (maybe with the DC heater upgrade from Bottlehead?).
DPetrini
Jr. Member
Reply #3 on:
July 09, 2023, 09:53:56 AM
Thanxs, which tubes i can use in stereomour II without modify It , that sounds Better than psvane 2a3c ?
Daniel
Paul Birkeland
Global Moderator
Hero Member
Reply #4 on:
July 09, 2023, 10:25:22 AM
Try a pair of RCA bi-plates.
Bottlehead Kits
Stereomour II
