Khozmo shunt stepped attenuator
DPetrini · 5706
Offline DPetrini
on: July 18, 2023, 11:43:34 PM
Have a khozmo 100k shunt stepped with vishay SMD resistors. The khozmo has amrg amtrans input resistor. I wonder if i should still keep the 33k resistors After the balance in the stereomour or not. Thanxs
Daniel
Good hand at solder , badhead in electronics
Reply #1 on: July 19, 2023, 02:39:59 AM
The 33K resistors are part of the balance control, not "after" it. They make it act more like a pan-pot, maintaining total loudness while shifting the image from side to side.
That said, a shunt-mode control will have a variable input resistance - if the term is used in the usual way. (All these terms are used a little loosely!) In that case, the behavior of the balance control will change a little when the volume changes. Probably not enough to notice, just a technical detail.
p.s. What doess "amrg amtrans" mean?
« Last Edit: July 19, 2023, 02:42:06 AM by Paul Joppa »
Offline DPetrini
Reply #2 on: July 19, 2023, 02:58:23 AM
Thanxs, amrg amtrans are boutique  resistors. I think they are carbon successors of riken
Correct the khozmo has variabile input resistance!
Will It be good then if i remove the balance pot? And if i do It shall i put any resistor Between the selector and the volume or Just a direct connection? The khozmo vishay smd has great Channel matching and keep the balance Will be a more compensating things than a real need
« Last Edit: July 19, 2023, 04:01:59 AM by DPetrini »
Daniel
