S.E.X 3.0 voltage check
Aosh · 4622
Offline Aosh
on: July 28, 2023, 12:47:59 PM
Hi All,
First time build, S.E.X 3.0 build passed all checks. On the last voltage check though,  instead of (0) I am getting 22v on terminal 4, and 25v on terminal 18, not sure if this is ok to proceed, I am on 220v power outlet, any guidance will be appreciated.
« Last Edit: July 28, 2023, 12:50:01 PM by Aosh »
Reply #1 on: July 28, 2023, 12:57:42 PM
Are you sure that's not 22mV and 25mV?
Offline Aosh
Reply #2 on: July 28, 2023, 01:15:51 PM
Just doubled checked, I believe you are correct, it seems I did not notice the readings, in that case, can I proceed further with headphones and check for sound?
Reply #3 on: July 28, 2023, 02:51:45 PM
Yes, that's plenty close to 0.
