Passing Resistance and Voltage Checks, yet no Sound? [resolved]
raps1514 · 4914
Offline raps1514
Hello, new BHC builder here. Never done anything like this before and am having fun. So, after "passing" the Resistance and Voltage Checks - I am not getting any sound. I'm sure I've done something wrong, so looking for help. Thanks!
1. *
2. *
3. 0 Ohm
4. *
5. *
6. 0 Ohm
7. 2.92 KOhm
8. 0 Ohm
9. 2.92 KOhm
10. 0 Ohm
12. 0 Ohm
13. *
14. 0 Ohm
20. 0 Ohm
22. 0.02 Ohm
B3. 2.92 KOhm
B6. 2.92 KOhm
RCA Red Center Pin: 98.3 KOhm
RCA Black Center Pin: 98.0 KOhm
RCA Red Ground: 0 Ohm
RCA Black Ground: 0 Ohm
1. 79.4 V
2. 166 V
3. 0 V
4. 166 V
5. 78 V
6. 0 V
7. 103 V
8. 0 V
9. 104.7 V
10. 0 V
« Last Edit: September 12, 2023, 06:37:08 AM by Paul Birkeland »
Reply #1 on: September 11, 2023, 07:08:51 PM
The headphone jack needs to be correctly installed and wired correctly, then you'll likely get sound out of your amp.
Offline raps1514
Reply #2 on: September 12, 2023, 05:48:12 AM
Thank you, Paul. That fixed it.
Offline pugys
Reply #3 on: December 21, 2023, 10:23:45 AM
What was the issue with the headphone jack connection? Is it that the wires are connected on the wrong side of the jack? I'm only asking in case I have a similar issue.
Reply #4 on: December 21, 2023, 10:36:23 AM
The headphone jack in this build was installed 90 degrees off from what's specified in the manual and the wiring is connected backwards.
