Morepaly output
Guest · 6229
AG
on: September 12, 2023, 03:22:00 AM
Hi to all.
 After finished the Moreplay and tested everything work fine.
just curious about the outputs there is a resistor between the outputs. how its works and why not just a bridge, I am missing something?
two outputs are for one amp and headphone amp, thanks for let me know the idea behind of two output.
Cheers from Fla.
Andre.
Offline Larpy
Reply #1 on: September 12, 2023, 04:20:20 AM
Those resistors help to isolate the two outputs so they won't interact as much when you have two different devices installed.
Larry
AG
Reply #2 on: September 12, 2023, 05:04:53 AM
Thank you for the quick response!
Cheers from Fla.
Andre.
Reply #3 on: September 12, 2023, 06:29:33 AM
If you have really long interconnects going to something like a powered subwoofer, putting those after the 220 ohm resistors will provide some isolation between that cable capacitance and the other output of the Moreplay, which is helpful.
AG
Reply #4 on: September 12, 2023, 06:48:17 AM
Understand. thank you, Paul.
Cheers from Fla.
Andre.
