Bottlehead Kits
Eros Phono
High Voltage
High Voltage
Toys4Boys
14411
Toys4Boys
Full Member
High Voltage
September 27, 2023, 04:46:53 AM
I am reading 260V-280V on the legs of the MJE5731A transistors, double checked my connections and can't see any problems.
Toys4Boys
Full Member
Re: High Voltage
Reply #1 on:
September 27, 2023, 05:24:02 AM
Just checked the 275V out from the PS and of course it is high, so I need to recheck my transformer wiring.
Toys4Boys
Full Member
Re: High Voltage
Reply #2 on:
September 27, 2023, 06:47:30 AM
went back to the transformer wiring, traced my connections and double checked my readings at which point I realized that the 275V out from the PS was in the printed limit. Guess I need to go over my shunt board again.
Paul Birkeland
Global Moderator
Hero Member
Re: High Voltage
Reply #3 on:
September 27, 2023, 07:32:51 AM
What are your Kreg voltages?
The +275V of the power supply board will go higher if no current is being drawn from the power supply. The MJE5731A collectors will also be much higher than they are supposed to be if no current is being drawn through the circuit.
Toys4Boys
Full Member
Re: High Voltage
Reply #4 on:
September 27, 2023, 09:38:19 AM
Should I insert the 12au7? Also please be specific as to where I should attach my probes.
Paul Birkeland
Global Moderator
Hero Member
Re: High Voltage
Reply #5 on:
September 27, 2023, 01:35:53 PM
Yes, the 12AU7 needs to be installed to test the board that lives above the 12AU7. You can slip your black meter probe into the ground post so that you don't have to hold it. The red probe should measure DC voltage on each Kreg pad.
Toys4Boys
Full Member
Re: High Voltage
Reply #6 on:
September 27, 2023, 02:23:04 PM
Kreg A 3.37 Kreg B 2
Paul Birkeland
Global Moderator
Hero Member
Re: High Voltage
Reply #7 on:
September 27, 2023, 03:10:24 PM
And you are seeing 260-280V on both MJE5731A metal tabs?
Toys4Boys
Full Member
Re: High Voltage
Reply #8 on:
September 27, 2023, 03:14:15 PM
Memory serves well yes, but I can double check
Toys4Boys
Full Member
Re: High Voltage
Reply #9 on:
September 27, 2023, 04:11:29 PM
OB - 260, Center - 219, IB - 281
IA - 280, Center - 218, OA - 281
Paul Birkeland
Global Moderator
Hero Member
Re: High Voltage
Reply #10 on:
September 27, 2023, 04:16:28 PM
What does center mean?
Toys4Boys
Full Member
Re: High Voltage
Reply #11 on:
September 27, 2023, 04:24:06 PM
are there not 3 legs?
Toys4Boys
Full Member
Re: High Voltage
Reply #12 on:
September 27, 2023, 04:27:21 PM
The designations that I used are what I could see on the board, they are actually Q2 - F,C,B
Paul Birkeland
Global Moderator
Hero Member
Re: High Voltage
Reply #13 on:
September 27, 2023, 04:30:54 PM
Definitely do not try to probe the legs of the transistor. It's tough to do and if you short two legs together, more damage will occur.
You have "Center" being the middle leg at 218 and 219, does this voltage also appear at the metal tab of the transistor?
Toys4Boys
Full Member
Re: High Voltage
Reply #14 on:
September 27, 2023, 04:37:20 PM
Damn, I misunderstood the instructions and checked the legs of the transistors not the tab
, I'll check in the morning and let you know.
Bottlehead Kits
Eros Phono
High Voltage
