Eros2 Power Supply Voltage Check
Moodyhh · 3696
Offline Moodyhh
on: October 12, 2023, 10:10:24 PM
Hello All,
At the 6.3 Volt terminal point on the Power Supply circuit board, I’m getting 6.25 volts - is this considered acceptable?  At the + / - 275 points I’m getting 375.7 volts.
Moodyhh
Reply #1 on: October 13, 2023, 05:14:34 AM
Yes.
Offline Moodyhh
Reply #2 on: October 13, 2023, 05:39:53 AM
Offline Moodyhh
Reply #3 on: October 13, 2023, 05:42:00 AM
What can cause these minor variations, or was the 6.3 figure just a ballpark to begin with?
Reply #4 on: October 13, 2023, 05:52:31 AM
The tolerance of the resistors mounted next to the voltage regulator, as well as the accuracy of your meter.
Offline Larpy
Reply #5 on: October 13, 2023, 06:02:13 AM
Operationally, 6.25 volts is just fine.  I've built a fair amount of tube electronics over the years and I don't ever remember measuring exactly 6.3 volts on a tube's heater.  For most tubes, anything within 10% is acceptable, so that means anywhere between 5.67 and 6.93 volts is OK, but I prefer to be within 1-2%.  Which you are.
As PB pointed out, the precision of the dropping resistors plays a role on what voltage you get.  So does the AC voltage from your wall outlet.  Nominally, it should be 120 volts where I live (the U.S.), but it's common for many of us to see it a bit below or above that.  I imagine it's the same in the rest of the world as well.
« Last Edit: October 13, 2023, 06:33:33 AM by Larpy »
Larry
