What makes a cap sound "better" - can it be measured
ssssly · 12416
Offline ssssly
on: November 04, 2023, 12:58:55 PM
TLDR: Skip to proposed testing methodology and/or knowledge gap(5).
The question "what makes one cap (or resistor) sound better than another" is one of the questions I wanted to solve when I bought 2 S.E.X. amps. And now that I am rebuilding those amps I thought I would revisit that question with the addition of nearly 20 years of experience.
The original experiments I did, much like others, were resounding failures. There was simply no discernable data to be had taking individual, uncorrelated measurements with a multimeter or cheap old scope. I definitively determined that motor run/start caps sound like trash. But I didn't get any closer to why.
Hypothetical reason related to every weird snake oil advertising claim can be found. But nothing to objectively back anything up. No repeatable data that can be used predictively at least. Just anecdotal or group agreement that x material or brand sounds x way. Which doesn't sit well in my brain.
So being a systems integration and robotics specialist, and definitely not an analog or audio circuit designer I sat down and had a good think about how what I know, and am good at, could solve this question. And I think I may have a testing methodology that could provide useful data here.
In robotics one of the big problems is the tendency for free moving effectors to be herky jerky (yes that's the technical term). And similar group agreement, without data, predominated how to address this with roughly the same result. Not much.
Until a systems integration approach was taken to data collection.
Applied to analog circuits my hypothesis is this: That by using multiple scopes, data logging multiple attributes of the primary circuit points and then using rudimentary machine learning analysis to analyze that data, it should be possible to determine the effect that changing components has on the system. And most importantly, that the testing also needs to include fully correlated spectral and electrical analysis of a driven speaker.
This way the absolute values become moot. Only the difference between subsequent values are relevant. And as long as the test equipment has sufficient resolution to measure those differences and those differences are repeatable...a model can be built to predictive accuracy.
And given the advances in affordable measuring devices, hopefully it can be pulled off using affordable, prosumer gear such as Digilent Analog Discoveries, Umics, REW, Dayton or similar digital speaker testing equipment and custom trained open source AI.
Proposed (very loose) methodology:
Use multiple AD 2 digital scopes to simultaneously data log time correlated circuit conditions for each component under test and each major circuit block.
Construct a front and rear sealed anechoic speaker box with calibrated mics at fixed locations. Spectral analysis via REW. Electrical analysis via DATS.
Data crunching via a custom LLEMA model trained specifically to deal with the resulting data streams, formats and circuit topology.
Known knowledge gaps:
(1)The measurement points most likely to reveal useful data.
A brute force approach would require a pile of 40ish AD2s, laptops and a decent server to coordinate them. And that's more than I want to spend on a proof of concept.  I'd prefer to be around the 5ish AD2 mark for both cost and setup complexity. At least at the proof of methodology stage.
(2) Has anyone attempted anything similar? I wasn't able to find any similar testing conducted in the peer reviewed audio world.
(3) Are tube circuits temperature dependent enough to require not only time correlation but temperature correlation as well?
(4) Are tube stages stable enough to result in repeatable tests?
(5) If the equipment is sufficiently precise to measure differences, can those differences be correlated to something currently understood, measured and reported by the component manufacturer? And if not, is it something that can be measured about the component itself outside the circuit?
(5)Do I simply have too much time on my hands that would be better invested in learning how to carve bears out of logs with a chainsaw?
Reply #1 on: November 04, 2023, 02:10:50 PM
Some work and measurements in this area can be found here:
https://linearaudio.nl/cyril-batemans-capacitor-sound-articles
I think when you introduce a loudspeaker into the chain and try to measure changes from the loudspeaker, that could get pretty challenging.  I would limit the scope of what you're doing to either coupling caps or speaker crossover caps, but probably not both.
As far as temperature stability in tube circuits, etc., you could create a cathode follower with the grid at 0V DC and the cathode voltage fairly low (certainly less than 12V) to allow for hot swapping caps with minimal risk.
Reply #2 on: November 04, 2023, 03:35:01 PM
There are a few measurable "nonlinearities" (differences between actual capacitors and mathematically simple models), notably dielectric absorption and mechanical resonances, that have been suggested as explanations. But the real problem is the merit function. How can you measure the relevance without using listening tests? And humans are so variable that statistically meaningful evaluations would require an impractical number of humans. There are only some 8 billion people on this planet, after all.  :^)
Online Thermioniclife
Reply #3 on: November 04, 2023, 04:02:49 PM
Subjectivity indeed Mr. Joppa.
Offline ssssly
Reply #4 on: November 05, 2023, 07:41:47 PM
That work played a significant part in my initial interest. I have been wanting to reread it but couldn't find it. Thank you.
But it is very much the opposite testing methodology from what I am proposing. I know I can't out measure capacitor designers with known characteristics. And I'm operating on the assumption that if there were substantial correlations between known capacitor characteristics and audible changes in amplifier/speaker systems, they or someone else would have identified them already. For marketing purposes if nothing else.
I'm trying come at it from the complete other end. If I can't correlate the known characteristics of an individual component to audible change...can I correlate measurable changes in work to measurable changes in circuit conditions induced by changing a component. Because if there is an audible change between individual components, there must be a change in work. And the work being done only changes in response to the circuit conditions. So given a large enough data set of circuit conditions vs. work over time, correlations should be revealed. If the measurement tools are precise enough.
I agree the speaker measurements will make testing and analysis more difficult, but I'll just have to figure it out.
I didn't intend on using a crossover.
That follower sounds like a great idea. Would need to build a timed cap switching system for repeatability. But that's nothing a RPI triggered by the AD2 couldn't handle. Might be doable direct from an AD2.
As far as merit factor, I don't know that it applies unless one is making claims of "better" or "worse". What I would consider resounding success is demonstrating that when swapping (Component A) with (Component B) it results in an observable change in work. And that change in work correlates to an observable change in circuit conditions.
If I could show correlations between (Components A & B) and (Components B & C) sufficient to predict correlation between (Component A and C)...I'd throw a party.
Is A "better" than B or C because of any of that, I'll leave that debate to the folks who sell capacitors.
