Considering Steremour II
Mucker · 28767
Offline Mucker
Reply #15 on: December 18, 2023, 05:54:07 PM
Excellent. Many thanks!
Offline Mucker
Reply #16 on: December 29, 2023, 02:10:53 PM
Getting a good start on my build but have a question on determining the best wiring impedance for my Klipsch RF-7ii.
They spec at 8ohm and 101bB sensitivity but I've been reading across the web more realistic numbers of 4-8 ohm and 97bB.
What impedance would be best in your opinion? Thank you.
Offline hmbscott
Reply #17 on: December 29, 2023, 04:30:48 PM
I'm assuming you're referring to this? I don't know how to interpret that with respect to predicting the best impedance match. Maybe someone else can.
Scott
Offline Mucker
Reply #18 on: December 29, 2023, 04:44:18 PM
Hi and thanks.
I'm not trying to be too technical about it but was curious if 4 or 8 would be a better when wiring the output transformers.
I've been using my S3X at 4 ohms and they seem to do OK. I will no longer use the S3X as a speaker amp once the Stereomour is built.
The setup will be near field with speakers pointed directly at my listening position from no more than 12 feet away.
« Last Edit: December 29, 2023, 04:46:11 PM by Mucker »
Reply #19 on: December 29, 2023, 05:21:30 PM
The answer to this question is always, "try both and see" but I would start with 8...John
Reply #20 on: December 29, 2023, 05:38:10 PM
It may sound a little thin in the bass at 8 ohms due to the 3.5-ohm impedance dip - unless there is a room resonance around 150-200Hz to compensate. Normally, a dip below 5-6 ohms would indicate 4 ohms is likely to be best, but room acoustics plays such a big role, it's usually worth trying other impedances.
For what it's worth, Stereomour has a bit more damping than S.E.X.
If 4 ohms sounds better, you can even try 2 ohms!
Offline Mucker
Reply #21 on: December 29, 2023, 08:54:13 PM
Thanks everyone and great information Paul. I definitely do not want thin bass. I think I'll start with 4ohm and go from there. Appreciate the feedback.
Offline Mucker
Reply #22 on: January 06, 2024, 05:16:14 PM
I finished mine today.
« Last Edit: May 01, 2024, 07:44:54 PM by Mucker »
Offline hmbscott
Reply #23 on: January 06, 2024, 06:36:01 PM
It's very handsome in mat black! A nice tidy build as well, I hope mine goes that well.
Scott
