Parabee parafeed cap?
RPMac · 7089
Offline RPMac
on: February 09, 2011, 04:33:42 AM
I have check this and the old forum for recommended value for the parafeed cap in the parabee and could find none. Stock is a 3.3 uf Solen...iron is TFA-2004 Ni and EXO-03 plate choke...JJ 300B. I have some 10uf Obbligato caps and 3.3uf Jensen caps. Recommendations?
Reply #1 on: February 09, 2011, 09:56:47 AM
My measurements - some years ago - indicated the EXO-03 has plenty of inductance, more than the rating. So I would go with the 10uF - I calculated 8.9uF, with a range of 5 to 20 being acceptable.
Offline RPMac
Reply #2 on: February 09, 2011, 10:16:08 AM
Thanks, Paul...that's what you recommeneded with my paraglows, but didn't know if the different OPT changed things.
Offline AudioDave
Reply #3 on: February 10, 2011, 01:16:28 PM
I still have the 3.3 uF caps in my Parabees and would like to upgrade to the 10 uF 630V caps.  Does anyone have a preference as to brand and where to buy?  I did some checking and it doesn't appear that Auricaps come that large.  I know Parts Connexion has a good selection.  Anywhere else I should shop?
Dave
Reply #4 on: February 10, 2011, 06:01:25 PM
The Obbligato caps, from DIYHIFI or Parts connection, sound great as parafeed caps. Auracaps are a perennial favorite. I prefer the Obbligatos...John
Offline RPMac
Reply #5 on: February 11, 2011, 04:46:35 AM
I'm not Granger, but I like Obbligato ;>D
I think Obbligatos and Auricaps are similar in that they both bring out 'detail'. I think both are caps you can't go wrong with using.
For ref.>>>squeezebox(apple lossless format)>FP III w/ OB 2.2uf(non-extended...yet)> Parabee w/ Auri coupling and OB parafeed caps...JJ 300b> Klipsch Hersey II w/ Auri's in crossover. Except for the cap changes, everything else stock.
With the 3.3uf Solens, the sound was nice and out in front of the speaker.
With the 10uf OBs, the sound stage became deeper, more bass(cut back on my subs in Sexy speaker arrangement), more detail.
The parafeed cap is between the plate/choke and OPT. I also returned the bottom of the OPT to the cathode(hum pot center terminal) instead of grd.
« Last Edit: February 11, 2011, 04:53:30 AM by RPMac »
Offline AudioDave
Reply #6 on: February 12, 2011, 03:57:46 AM
Thanks for the recommendation,  Obbligatos it is!  You said that you returned the bottom of the OPT to the hum pot center terminal instead of ground.  What does that do and why is it recommended?
Thanks,  Dave
Offline RPMac
Reply #7 on: February 12, 2011, 04:23:31 AM
Thanks,  Dave
This is something Paul recommended. As I understand it, it takes artifacts from the cathode bypass cap out of the signal loop. PJ can correct me if I'm wrong and, of course, do a much better job of explaining.
I bought my OB caps from DIYHiFiSupply and there are more 'flavors' now. I don't think they will disappoint.
