Mon Amour coupling capacitor size
Altecboy · 15676
Offline Altecboy
on: December 03, 2023, 07:44:14 AM
The stock size for the coupling capacitor is 0.1uF.  I have a few Teflon Russian caps I'd like to try.  Unfortunately they are 0.022uF.  Will this be to low for stability?
Thanks for any replies.
Reply #1 on: December 03, 2023, 08:51:24 AM
The issue is not stability, but bass response. The capacitor drives the 259K grid resistor of the 2A3. I normally set the corner frequency pole at around 5Hz, which has worked well in many amps. Reducing the capacitance to 0.022uF would raise that point to 29Hz. (At the pole frequency the signal is 3dB down and 90 degrees out of phase with the midband.)
There are many arguments about the best approach. Some apply a phase shift rule and conclude the pole should be at 2Hz or lower; some say it should be higher to avoid driving the output transformer into saturation on music with heavy bass transients.
A point more rarely mentioned is that the recovery time from transient overload (grid current in the output tube) is proportional to the capacitance. A smaller capacitance recovers more rapidly. I have not seen any reliable data on the audibility of recovery time, though.
In short, it's worth trying. There's not much bass below 30Hz, after all. Remember, most teflon caps seem to need 100-500 hours of music to reach their best sound.
Offline Altecboy
Reply #2 on: December 03, 2023, 09:08:57 AM
Thanks for the reply.  I was sloppy.  I meant to say 0.22uF.
Reply #3 on: December 03, 2023, 09:22:38 AM
It's still a reasonable experiment.
Offline Altecboy
Reply #4 on: December 03, 2023, 09:26:49 AM
Excellent.  Thank you for the quick reply, Paul.
Offline Altecboy
Reply #5 on: December 04, 2023, 09:05:12 AM
So Paul,  I put in the 0.22uF FT-3 Teflons.  This sounds very different than the K72 units which have steel shells.  The FT-3's are aluminum or some other non-magnetic metal.  FT-3's sound awfully good.  If you would like a pair, let me know and I'll send them to you.
thanks again,
Les
