Mainline Resistance Check
bdog9 · 51795
Offline bdog9
Reply #30 on: January 17, 2024, 11:52:09 AM
I did. But now I do not. Solder joint had broken loose.After it was repaired everything sorted out on its own.Both sided biased to 145. Could not have done it without your help. Next time your in Fort Worth call me and I will make a steak dinner. Bill
Reply #31 on: January 18, 2024, 06:31:15 AM
I do get to Texas from time to time...
One thing I would recommend in your instance is to plug in some cheap headphones and play music through your amp, then give the top panel a few hard whacks with your hand.  If the music keeps playing uninterrupted, then it's rather unlikely that there are any other issues that may pop up.  If the music drops or pops, then you may need to poke around a bit more to look for other loose/broken stuff.
