Mainline Resistance Check
bdog9 · 52093
Offline bdog9
on: December 07, 2023, 05:09:10 AM
 Need a little help getting pass the resistance check.
 I have gone over wiring multiple times and feel confident that it is correct. I lingered however, on the soldering of connections 6 and 8 on the input switch. I am guessing I will need to replace it.
 Terminal 1 and 5 are reading OL, 15 and 25 are reading 205.5 and 207.5 respectively. All others are in the 0.1 to 0.3 range.
Advice would be appreciated. Bill
Reply #1 on: December 07, 2023, 05:49:30 AM
Could you post some build photos?  Do you get a different resistance reading on 1 and 5 if you turn the fine switch all the way down?
Terminals 15 and 25 are supposed to read around 200 ohms, so I don't see an issue there.
Reply #2 on: December 30, 2023, 08:31:29 AM
Inspecting the photos you sent me, could you let me know what meter you're using?
Offline bdog9
Reply #3 on: January 02, 2024, 07:38:39 AM
Thanks for the help. I measured with a Klein CL390
Reply #4 on: January 02, 2024, 09:22:34 AM
If you turn the fine control all the way up and the coarse control all the way up, what's the DC resistance reading on the center post of each 6C45 socket?
Offline bdog9
Reply #5 on: January 03, 2024, 07:18:10 AM
130.0 for both
Offline bdog9
Reply #6 on: January 03, 2024, 07:19:31 AM
Sorry, fat fingers. Should be 139.0 for both.
Offline bdog9
Reply #7 on: January 03, 2024, 10:00:58 AM
I made an asumption that could be wrong. I measured from the ground at the power cord to the center of the outer tube sockets. If wrong by all means correct me.
Reply #8 on: January 03, 2024, 03:29:32 PM
That doesn't make a lot of sense, was the coarse control turned all the way down by chance?
If the answer to that is yes, then that tells us that the coarse attenuator seems happy.  The next resistance check would be to the lower two lugs on the fine switch with the fine switch turned all the way up.
Offline bdog9
Reply #9 on: January 04, 2024, 04:16:48 AM
PB your patience is admirable. Thanks. Now I know full clockwise is up, and full counter clockwise is down.
The fine lug reading fully up was OL to either of the lower lugs.
Reply #10 on: January 04, 2024, 04:46:17 AM
Can you check that resistance reading with the switches in those positions against the resistance reading of the center lug of each 6C45P jack?
Offline bdog9
Reply #11 on: January 07, 2024, 10:29:54 AM
 Measuring with fine and course all the way up, clockwise, the resistance reading between ground and the center lug of the 6c45p both right and left is OL.
Reply #12 on: January 08, 2024, 05:43:27 AM
What I would do is to hold a probe on one center socket and turn the coarse switch back down and stop when you see a resistance reading.  Let us know what that resistance is and what step you're on with the control.
I am somewhat confident that the meter you have just isn't properly reading large resistance values, though it is advertised as being able to do so.  If you lose the DC resistance value on both center pins of both 6C45P sockets at exactly the same step on the coarse switch, I would tend to blame the meter.  If the resistance reading drops out on one side but continues counting up on the other and then drops out, I would suspect flaky solder joints on the coarse switch itself (though doing a ton of resoldering on these switches is not at all recommended).
If the meter is the problem, the ~$20 meter at Harbor Freight can resolve these measurements.
Offline bdog9
Reply #13 on: January 09, 2024, 05:02:22 AM
I started seeing resistance reading when I reached -36dB. It registered 394 both socket. At -45dB it dropped to 139.5 both sockets. I then switched to another multimeter and everything improved. 5 and 12 now register 39.5. I am reading resistance all along the coarse switch but the reading between center socket both sides and ground is still 394  at -36dB. It then drops to 139 when at -45dB and I wonder if I should question that or move on to voltage checks ?
Thankyou for your help.
Reply #14 on: January 09, 2024, 05:34:39 AM
The resistance readings at the center pins of the 6C45 sockets should go from close to zero up to about 25K as you rotate the coarse switch assuming the fine switch is turned all the way up.  Provided you see those resistances present, you can move onto the voltage checks.
