Bottlehead Kits
Moreplay
Raw B+ voltage
Raw B+ voltage
denti alligator
3553
denti alligator
Hero Member
Raw B+ voltage
December 31, 2023, 09:38:55 AM
I just finished this test. I got a reading that started around 320 and went up little by little to around 324, then down a little, then back up. Should I assume everything is ok? (Incoming voltage is 123V)
- Sam
hmbscott
Full Member
Re: Raw B+ voltage
Reply #1 on:
December 31, 2023, 12:36:41 PM
When I built mine it measured about the same, 321 - 324 VDC in my case. I have a similar line voltage; it varies between 120 and 125 VAC. I assumed it was fine and completed the build with no issues.
Scott
denti alligator
Hero Member
Re: Raw B+ voltage
Reply #2 on:
December 31, 2023, 06:29:57 PM
Thanks. From other posts here I assume it’s ok. Happy New Year everyone!
- Sam
Bottlehead Kits
Moreplay
Raw B+ voltage
