Bottlehead Kits
Crack
Broken HLMP-6000 LED
micheld
3312
micheld
Newbie
January 18, 2024, 04:06:38 AM
Morning
One of the HLMP-6000 LED is broken
What are my options?
- replace with a solid wire
- replace with a diode
- try to source a new HLMP-6000 LED
michel d
Larpy
Full Member
Re: Broken HLMP-6000 LED
Reply #1 on:
January 18, 2024, 04:37:04 AM
Broken as it arrived in the kit broken in two? If so, contact Bottlehead and they'll send you a replacement.
Broken meaning it broke into two when you attempted to solder it into the circuit? If so, you'll need a replacement. (Do not use a piece of wire or another diode.) You can order replacements here:
https://bottlehead.com/product/hlmp-6000-leds-prod/
Last Edit: January 18, 2024, 04:40:47 AM by Larpy
Larry
Paul Birkeland
Global Moderator
Hero Member
Reply #2 on:
January 18, 2024, 06:26:18 AM
It is possible to temporarily install a wire between A3 and A8 to get your kit up and running, but you should put the second diode back in when you can. Doing this workaround will reduce the available information if you run into problems as well.
Bottlehead Kits
Crack
