Help deciding between Moreplay and BeePre2
ambd1 · 34697
Offline ambd1
Reply #15 on: February 09, 2024, 05:12:26 AM
Alan,
This evening I hooked my Saga back up and did some listening comparing it and the Moreplay. Cable swapping isn't ideal, and results are interesting enough that I want set them up for up for a proper A/B test. My initial impression is that the differences are not enormous, but may be audible. With the Saga in the chain, the treble region is sharper/harder, but not exactly harsh. I noticed this with a couple of songs with high-pitched, high-volume content, Numb on Portshead's Dummy Album and Adele's Hello on her 25 album. Sound stage and imaging are similar. I was surprised that the Saga is as sweet sounding as it is, which is why I want to do proper A/B testing.
Thanks for comparing the sound with the Saga and with the Moreplay in the system. Your experience is really interesting and, for me at least, somehow unexpected as I have read in many forums that the Saga did not bring much to the sound in comparison with a real tube preamplifier, such as the Moreplay. But, as you mentioned, you may need to properly set up an A/B test (taking careful account of gain in both cases) to have a confirmation. I exchanged some emails with Schitt technical people some weeks ago, and they confirm that according to their experience, their tube device that could bring more ¨tube¨ sound to a given system is their Freya +.
Offline hmbscott
Reply #16 on: February 09, 2024, 08:13:48 PM
I did a bit of AB testing and the Saga sounds great! I don't hear even a hint of harshness. If I had never listened to the Moreplay I would be totally satisfied with pairing it to the Nilia.
While the differences are subtle, they add up. The Moreplay is more immersive, engaging, and less fatiguing, but it's not soft or mellow. Percussion is sharp, startling, tight. Subtle texture is more distinct and voices better articulated. Instruments are more full and musical especially noticeable with piano, guitar, and bells. High volume high pitched passages are smoother, sweeter, less shrill. It gets me a little closer to experiencing a performance rather than hearing a recording.
Scott
Offline ambd1
Reply #17 on: February 10, 2024, 03:54:11 AM
Thanks for doing the AB testing. It is very helpful. Kudos to the Saga, but surely the Moreplay had to produce a more engaging sound. Then, the Moreplay it is for me.
Having said that, I did overlook a complex issue in my system and I would like to ask your help with ideas on how to solve it.
As I explained, I have a Mini DSP being used as DAC, source selector and also crossover, sending one low pass signal with EQ to the subwoofer via RCA, and one high pass signal with EQ to the NCx500 amplifier via RCA, for the main speakers.  And surely, I control the volume of the whole system with the MiniDSP volume knob. This knob controls the 2 volt max of both RCA outputs, at the output stage, going from 0 to 2 volts.
In order to introduce some tube sound without much complications, the ideal place for the tube preamplifier would be after the Mini DSP. But, in this case, the problem is that the tube preamplifier will not receive a full signal level but rather a signal going from 0 volts to 1.4 volts (because the MiniDSP is controlling the volume through the volts in its RCA output).
So, the input signal received by the tube preamplifier will vary depending on the volume. And I think that is not what a preamp expects, since most preamplifiers are designed to receive input signals with a predefined voltage and control the output signal to the power amplifier by adjusting the gain of the preamplifier stages.
In short, at low or mid listening levels, the signal sent from the MiniDSP to the preamplifier will be too weak and will probably degrade SNR and distortion performance in the tube preamplifier.
If, on the other hand, I place the tube preamplifier before the MiniDSP, I would need the tube preamplifier to have all the input sources I need, since it would act a source selector, but it would also need to be a unity gain preamplifier of some sorts, because the RCA input of the MiniDSP cannot take more than 2 volts.
I am thinking (but most likely I am missing something) that my best option may be to find, commission, or build a unity gain tube preamplifier with as many sources as I need.
Reply #18 on: February 10, 2024, 06:10:24 AM
This is what you want to do.  2V is a pretty hefty amount of signal and the Moreplay doesn't have a whole ton of gain.  You can also add a couple of resistors to the volume control if you need to in order to set the gain to unity.
Offline ambd1
Reply #19 on: February 10, 2024, 08:12:03 AM
Thanks Paul. Yes, you are right, that would be probably the ideal scenario and if the Moreplay is close to unity gain then that is great.
In this scenario, the Mini DSP will receive around 2V or bit less from the Moreplay, and it will work as a EQ, crossover, and master volume control for the whole system. Also, in this scenario, my gain structure on the amplifier side will stay the same, which I like a lot.
I am not so good at modifying schematics but I can ask for advice here on how to deal with those resistors when the time comes. My sources are just two: DAC (together with bluetooth in the same device) and the phono preamplifier coming from turntable. In that regard, the Moreplay has two sources input or just one?
Offline hmbscott
Reply #20 on: February 10, 2024, 08:48:45 AM
The Moreplay has three inputs and two outputs. The outputs are both active all the time.
I added an Lpad to my Moreplay to reduce the gain a tad. The Moreplay normally will output 5.5V with a 2V input. I just calculated a new Lpad that will change that to unity gain, 2Vin >>> 2Vout. See the drawing, it specifies the resistor type I used. Mouser caries them, both values are in stock. Paul, please correct me if I got this wrong.
« Last Edit: February 10, 2024, 08:50:30 AM by hmbscott »
Scott
Offline Mucker
Reply #21 on: February 10, 2024, 01:19:20 PM
FWIW, I reduced the gain on my Moreplay a while back using 2W TKD resistors (7.5K and 3.3K) on the stock pot. They are overkill for certain but very effective and less than $10 total. Pic is a visual for reference. For unity gain, it sounds like using Scott's calculated one's in place of the one's I used?? Interesting discussion and thanks (all) for the info about making a unity gain Moreplay.
« Last Edit: February 10, 2024, 01:35:51 PM by Mucker »
Offline hmbscott
Reply #22 on: February 10, 2024, 06:08:52 PM
The resistor power rating required is quite low. Power dissipation based on a fixed voltage input is V^2/R = Watts. Assuming the highest voltage drop of 5.5V and the lowest resistance mentioned, that's 5.5^2/3300 = 1/100 of a watt. Any larger resistor will dissipate less power.
Scott
Offline ambd1
Reply #23 on: February 11, 2024, 01:51:44 AM
Hi Scott!
Thanks a lot for taking the time to modify the schematic of the Moreplay for Unity gain. I really appreciate it. And 3 inputs is more than what I need. I will order the kit this week, and I will start putting together the preamplifier next weekend!
If I understood correctly, the only extra pieces I need to buy to achieve unity gain are those two resistors, is that right? because there is an L Pad in the kit I think.
And lastly, it would be good for me to not just solder but understand (even if it is just on a surface level) what is happening in the circuit. Is there any book that you would recommend to somebody to start understanding basic electronic principles for tube amplification?
Once again, thank you and everybody for being so helpful.
Offline hmbscott
Reply #24 on: February 11, 2024, 10:40:32 AM
Alan, The two resistors are the Lpad (that term just is the name for connecting resistors to a signal input in that configuration) and yes, they are the only thing you need. You will connect them to the volume pot that comes with the kit. Note that you need two of each resistor, one for the left channel and one for the right channel. The kit doesn't include an Lpad.
Congrats on that choice, I'm sure you will enjoy both the process of building it and listening! And you will be amazed by the incredible value it represents.
One pretty good site to learn about tube tech is The Valve Wizard and this page is a good place to start: http://www.valvewizard.co.uk/gainstage.html. The author is British so some of the terminology differers from American terms.
The Moreplay, and most Bottlehead circuits are triode based and the majority are of the type known as common-cathode, which means the cathode is connected the ground circuit, usually with a low value resistor (hundreds of ohms) that sets it's bias. Bottlehead designs are not simple triode circuits though. They include several sophisticated and in some cases unique circuit designs that set apart their circuits in ways that contribute both their ease of construction, but more importantly, their superior performance.
Here's a bit of terminology can get you started on understanding the material, forgive me if you already know all this, but if you don't, it will really help comprehending the information at the beginning.
Valve - Britt's term for tube.
Common - refers to the ground circuit and basically means grounded. It comes from the fact that all parts of the circuit that a grounded are connected to the same "common" ground. By convention it is zero volts in the circuit and all other voltages are defined in reference to the ground being zero volts. You may also see a term "referenced to ground" which means either connected directly to ground with a wire, or with a resistor. Using a resistor will introduce a voltage offset if current flows (see Ohm's Law below).
Triode - A tube with three connections, Cathode, Grid, and Plate or Anode
  • The Cathode is heated to allow it to freely emit electrons.The cathode is held at a low slightly positive voltage typically
  • The Plate is held at a high positive voltage and will attract electrons from the cathode
  • The Grid is an open mesh electrode between the cathode and plate. By being placed so it's voltage is what the cathode experiences rather that the plate voltage, which the cathode would experience if there were no grid. The grid's voltage is modulated by the audio signal. By doing so it reduces electron flow from the cathode when the voltage dips and increases electron flow when the voltage rises. This causes a modulated current to flow to the plate, and that current passes through a load resistor producing a much larger voltage audio output signal (again see Ohm's Law below to understand the idea of a resistor converting current to voltage).
Bias - refers to setting the zero signal voltage relationships between the cathode, grid and plate. This is a design parameter that sets a tube to operate in a range of voltages suitable for the circuit's function. In the simplest case, bias is set with resistors connected either to ground or the B+ voltage, also called rail voltage or "rails".
B+ - refers to the high positive voltage that's provided by the amplifier power supply. Ideally it will remain a a fixed positive voltage typically in the 150 - 600 VDC range for tube amplifiers, the specific value depends on the operating needs of the tube type used. How well the power supply is designed will have a huge influence on how stable that voltage is under varying load and how free it is of AC ripple and noise. Any variation in B+ will result in unwanted modulation in the output audio signal, which is why power supply design is so critical. BTW, Britts call B+ "HT", short for High Tension. Tension is an old-timey British term for voltage.
Ohm's Law - This is super useful in understanding resistors: V = I X R, Voltage = Current times Resistance. The units are volts, amps, and ohms. This equation can be used to calculate bias voltages etc.
The Power Law - This allows you to calculate power if you know the voltage and current: P = V X I, Power is equal to Voltage times Current. The units are Watts, Volts and Amps.
Combining Ohms's Law and the Power Law allows calculating all kinds of useful things, like power dissipation in wire or resistors, speaker power output, and amp loads etc. One common way to use the combined equations is to substitute for voltage in the Power Law from Ohm's law, which gives this equation:
  • P = I^2 X R  This can tell you how much power is dissipated by wire or a resistor or a speaker if a constant current source is connected to it. If you substitue for current instead you get this equation.
  • P = V^2/R  This can tell you power is dissipated if a constant voltage source is connected.
These are the most important equations for understanding what electrical circuits are doing, and as you can see, they are surprisingly simple. But it's quite amazing how deeply your insight can be by learning how to apply them.
Scott
Offline ambd1
Reply #25 on: February 16, 2024, 06:03:22 AM
Scott, thanks a lot for the explanation and the links!!! I really appreciate it. I got a little derailed since we started a new project at home. I will surely read the Valve Wizard site.
Offline jasmine333
Reply #26 on: December 12, 2024, 01:39:15 AM
I had a similar issue when integrating tubes into my setup. In practice, Moreplay works great with MiniDSP, but fine-tuning the resistors is key. If you enjoy DIY, check out Valve Wizard – it’s packed with helpful info!
Offline hmbscott
Reply #27 on: December 12, 2024, 07:43:36 AM
ambd1,
I recently revisited the LPad in my Moreplay and after much advice from both Pauls and me learning a thing or two, I have moved my Lpad from the location shown above to between the selector switch and the balance pot. This puts it upstream of the tube and per Paul, in a location that has less negative impact on the sound. I found a significant improvement in highs in my system after making this change. With the original LPad location at the Volume pot the highs had been somewhat rolled off, now they are back and it's really noticeable on cymbal passages, so thanks Paul! I also learned a lot about selecting LPad resistor values to have less impact on the impedance of the circuit. Here's the new circuit location and where I physically put them in the amp (Note the black resistors on the wires between the selector switch and balance pot).
« Last Edit: December 12, 2024, 07:53:54 AM by hmbscott »
Scott
Offline DPetrini
Reply #28 on: December 13, 2024, 07:53:02 AM
Very interesting discussion. I have the nilai as well, and can confirm it needs long break in time and it benefits from Tube warm sound injection. I was incline to think to buy a beeper to inject warm, but if I understood correctly between the beepre2 and moreplay the moreplay has more tube classic sound?
« Last Edit: December 13, 2024, 08:10:00 AM by DPetrini »
Daniel
Good hand at solder , badhead in electronics
Offline hmbscott
Reply #29 on: December 13, 2024, 08:44:57 AM
My recent post regarding moving the LPad in my Moreplay and the impact that had on the high frequencies may be relevant to my earlier impressions of the Moreplay vs the Saga with the Nilai. It may explain the fairly stark high frequency difference between the two that I noted. Although I should note that I am no longer using the Nilai. It was replaced by a Stereomour, and that may have some influence over my recent observations.
Scott
