Channel imbalance from 6.35mm only
hpleung · 6087
Offline hpleung
on: February 09, 2024, 06:47:19 AM
Hi,
So i normally use the xlr connection and that works fine. Lately i tried the 6.35 headphones jack.
When i flip the switch to “unbal”, i get higher volume but also the right side is louder than the left side.
No still with the 6.35 jack, when i flip the switch to BAL, the balance problem seems to go away.
Are there any pointers on where i should investigate to resolve this imbalance problem?
Reply #1 on: February 09, 2024, 07:13:59 AM
I would look for a loose wire or a cold solder joint around the area of the 4 pin and TRS jacks.  Don't overlook that it could be a wire leaving the 4 pin jack that's the issue.
