Dimensions
Deluk · 9975
Offline Deluk
on: February 21, 2024, 02:47:01 AM
What is the base footprint size of the Moreplay? How many sizes are there for the various products? I have a Crack so there may be others that share that base size. As far as I can see the dimensions don't appear in the specs of the products. I find this a bit surprising. Thanks.
Reply #1 on: February 21, 2024, 08:18:40 AM
Crack uses a 6"x10" chassis panel. The old Seduction and Quickie kits used this as did the very first SEX amp, Paramour and Foreplay kits from the 90s. Also The Fix and Submissive. Probably some others I am forgetting.
Moreplay uses an 8x10 panel, as does the S.E.X. amp. As will the new subwoofer amp.
Eros 8x12
Stereomour2 10x12
Mainline 12x12
BeePre2 and Kaiju are 10x16
Offline Deluk
Reply #2 on: February 22, 2024, 02:26:46 AM
Thanks Doc. I was actually after the case footprint i.e. the overall size so I can check how everything fits on a rack or shelf. Checking my Crack it looks s if I would need to add 1 1/4" to all of those measurements to get what I need assuming the wood parts are all the same thickness? The Alder is 3/4" thick. Shelf for plate is 3/16"
Reply #3 on: February 22, 2024, 05:37:07 AM
Yes the bases all add the same amount beyond the dimensions of the chassis panels, about 1-1/4"
Offline Deluk
Reply #4 on: February 26, 2024, 06:24:07 AM
Thanks Doc.
