Different Driver Tube
eeyore · 9185
Offline eeyore
    • Blog
on: February 12, 2011, 03:54:56 AM
If we divorce ourselves from the socket, B+ and heater requirements, what do you guys think would be the best driver tube for the Crack for general 90% listening?
Enjoying the Crack now, but feel the need to tweak and upgrade...
David
Bottlehead Crack :: HD650, Beyer DT880(600), ATH-D700
Offline Natural Sound
Reply #1 on: February 14, 2011, 06:12:37 PM
I took my amp in a different direction and used a 6SN7. You need to punch the top plate out for an octal socket. The rest of the components are the same. You just need to follow the different pinout of the octal. So far I haven't added the speedball upgrade. I like the sound just the way it is.
http://www.bottlehead.com/smf/index.php/topic,1222.0.html
Offline mrarroyo
Reply #2 on: February 15, 2011, 12:34:11 PM
Or you could use the 6CG7 the same as the 6SN7 and no need to punch a larger hole.
Offline GLF
Reply #3 on: February 15, 2011, 02:13:32 PM
I wired mine to take 6DJ8/6922. The only change was to the heater wires.
Andrew
Andrew Krafthefer
Reply #4 on: February 16, 2011, 05:53:38 PM
The 6CG7 has a very good following. If someone decides to use it in their amp please let us know how it sounds. I used the 6SN7 because I had a bunch of them lying around.
Reply #5 on: February 17, 2011, 05:11:50 AM
I'll suggest giving the 12BH7 a shot. It's sort of a beefier, more linear 12AU7.
Offline eeyore
    • Blog
Reply #6 on: February 20, 2011, 07:21:41 PM
12BH7 sounds like a good option. I have a good stash of 12SN7, and sounds like that would also be a good alternative. Any other tubes. Doesn't have to be triode or dual triode, and it could be a triode strapped pentode, two single triodes, etc?
David
Offline ToolGuyFred
Reply #7 on: February 21, 2011, 02:04:04 AM
I'm using a 12BH7 in mine and it gets a firm thumbs-up, but I didn't try it until I'd installed the speedball upgrade.
John
Amateur Audiophile and Backstreet Boffin.
Original Foreplay with C4S + Sweet Whispers
ParaSEX amps with MQ nickel-cored outputs
Factory-built Lowther Acousta 115s with silver-coiled DX3s, wired in DNM solid-core
KEF active sub (help for the last couple of octaves).
Bottlehead DAC on batteries.
Reply #8 on: February 22, 2011, 03:56:24 PM
Eeyeore,
You can't use the 12sl7 as it doesn't have a center tapped filament and the Crack only has a 6.3v heater winding.
Offline eeyore
    • Blog
Reply #9 on: February 22, 2011, 10:04:27 PM
Yeah, it's a new heater transformer to deal up 12sn7. I am actually thinking about either a 5687 family or 6n6p as well, so it's one of thtose three. How is the current set with the Speedball, cause all three tubes have a different current and grid bias. The 5687 looks like it may require higher B+ voltage to run well. The 6n6p seems to be a good balance with the current, B+ and grid bias.
David
Offline eeyore
    • Blog
Reply #10 on: February 22, 2011, 10:13:35 PM
6n6p looks like -4V @ 120V at 12.5 mA
5687 looks like -4V @ 125V at 21 mA
12sn7 looks like -3V @ 115V at 5 mA
I figured the above operating points based on a maximum of 170V on the B+. sound right? How to set the Speedball to get these figures. I guess I also have to change the bias LED at the cathode as well?
David
Offline eeyore
    • Blog
Reply #11 on: February 25, 2011, 08:20:05 PM
Hi, have decided use the 5687 family. Looking at the curves, a bias at -3.2V (that way I can use two HLMP-6000) and setting the current at 20mA, looks like the quiscient voltage is 120V. I suppose there'd be enough headroom with the B+ to swing from a -3.2V grid to -5.5V, meaning the other end is at -0.9V at 65V around the plate. Does that mean I nee d to make sure I can sink up to 2.1W at the C4S ((170V - 65V) * 0.020)?
How would I go about determining the resistors at the C4S to source 20mA? I assume R1 (237R) has to change, and so does the 150K as well?
Any suggestions or assistance appreciated!
David
Reply #12 on: February 26, 2011, 06:21:26 AM
I believe the Crack is designed to have the driver plate at 75v. That value is important because it is direct coupled.
