Bottlehead Kits
BeePre
BeeQuiet attenuator
Attenuator Replacement
Brillo
9149
Brillo
Full Member
March 22, 2024, 03:50:28 AM
Can I just replace the blue attenuator switches with a 50K ohm stepped attenuator? Is that the right value?
Chris
Paul Birkeland
Global Moderator
Hero Member
Re: Attenuator Replacement
Reply #1 on:
March 22, 2024, 04:54:17 AM
In the BeePre 1, you could use a single 50K attenuator in place of both switches. In the BeePre 2, that wouldn't work so well, and you'd want something closer to 5K.
Brillo
Full Member
Reply #2 on:
March 22, 2024, 06:12:45 AM
[For BeePre2] Perhaps a pair of Goldpoint 2-pole, 6-position selector switches, built up similarly? Are they not make-before-break type? I have a bad course switch, and debating whether to replace with same, or upgrade, if possible.
Last Edit: March 22, 2024, 06:15:54 AM by Brillo
Chris
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
March 22, 2024, 08:28:20 AM
We initially tried the Goldpoint switches for the first BeeQuiet attenuator and they didn't work properly. I would either diagnose what's going on with your coarse switch or replace it with the same part.
Bottlehead Kits
BeePre
BeeQuiet attenuator
