Can balance knob be bypassed
mmwwhats · 20241
Offline Finkle
Reply #15 on: November 09, 2024, 05:50:09 PM
I'm doing work with the inputs, how would I go about running the resistor across the input jacks? One end to hot and one ground on each RCA input?
Also relooking at the volume pot wiring, am I seeing the input grounds running to the output grounds? Connecting on the same pin of the of the chassis side terminal of the volume pot? Without the selector and balance pot, wouldn't I need to wire the grounds of the input and output jacks together at the jacks? Any chance I could use the 4 input jacks that are tied 4 grounds together at the same L bracket with little yellow resistors or diodes? Use 2 jacks for input 2 for output?
Reply #16 on: November 09, 2024, 06:15:39 PM
I don't really recommend doing this.  You have better control over the signal current running through the ground wires if all that is separated, and you may end up inadvertently creating ground loops if you deviate too far from the stock layout (which is tested).
Reply #17 on: November 09, 2024, 06:59:23 PM
Very helpful and reading through the lingo as someone explains my exact scenario does help me understand more than just reading. So thank you very much.
Are these terminal #s correct then? A5 to 2, and B5 to 12. Grid stopper is at the end of the chain to ground at 2 & 12 with the other end everything hot starts from there out and the voltage can't pass through the stopper from the hot side is from what it sounds. And it's just this 100k resistor being installed, no other components need to be added?
Again, i greatly appreciate your guidance and time on this.
No, the 100K goes from A6 to terminal 2 and B6 to terminal 12. The grid stopper is already wired A5-A6 and B5-B6. A6 and B6 are not used by the tube so it's effectively just another terminal. Remember, "a grid stopper only works if it is the only thing physically connected to the actual grid; all other "grid" connections are actually made to the other end of the grid stopper."
The photo in the manual of the completed preamp shows red/black twisted pairs, with reds going to A6 and B6 and blacks going to 2 and 12.  The other end of the twisted pairs is connected to the balance controls. Unsolder those twisted pairs from the balance control and connect them to whichever input RCA jacks you want to use. (Obviously you'll have to remove the existing wires from those chosen RCAs!) You can then put the 100K resistors at either end of the twisted pairs, whichever is easiest.
Offline Finkle
Reply #18 on: November 10, 2024, 05:17:36 AM
This has been greatly helpful and informative. Thank you guys! Feel like I've gained more understanding in the last day than the last few months combined.
If reducing inputs and working on them already it's the space already being worked on so that's where they'll be added in mine.
Last question...for now. What are the purpose of the little yellow caps at the intake jack grounds? Assuming I should be leaving them in when installing the 100k resistor from input RCA hot to ground? Would an output jack be able to use the yellow .01uf cap if I swapped a couple of the input jacks to output? Or would a different resistor or just bare RCA ground to ground for output jacks? As I'm rewiring the inputs and outputs, they're already tied to a ground and looking appealing to reuse if tieing all the grounds together, input and output, at the jacks.
Reply #19 on: November 10, 2024, 05:32:47 AM
The yellow caps present a very low impedance between audio ground and the chassis but only at very high frequencies.  This is a way to drain off high frequency gunk off the audio ground before it gets into the circuit.  These are not necessary, nor useful on the output jacks.
We have about three decades of preamp kits that never used these, so don't fuss too hard over them.
Offline Finkle
Reply #20 on: November 10, 2024, 01:35:18 PM
Live in the mix! Functional, sweet sounding preamp is back! Was a lot of changes at once, output cap change happened, also heavy duty on/off switch too. Been listening without it for 3 to 4 weeks. Immediately could tell it's going to be a lot of fun having it back. Engaging. Completely black at very high levels when music goes quiet, not that it wasn't before, just probably a good sign?!
A few things I think the next iteration could end up with: using the same red & black wire as sent with the kit, parts express wire coating is minimal. Probably add an on light. Not sure what chassis changes yet but probably stay the same external dimensions, finish the base. Reposition RCA jacks and iec power cord to the back.
Thanks again guys! Rockstars!
Offline Mucker
Reply #21 on: April 13, 2025, 04:57:11 PM
I'm digging up an old post but I feel it is relevant here.
I plan on buying the upgrade as soon as it is available for the improved power supply, but in the mean time I have a 10K, 24 step volume attenuator that I would like to test out with the balance pot bypassed.
Earlier in the thread, Paul said  "The easy way is to remove each red wire leaving the balance pot from each of the center lugs.  The red wire that left the top deck can be moved to the balance pot terminal with the white wire, and the red wire that left the bottom deck can be moved to the balance pot terminal with the red wire.
Is this in addition to adding the 100K resistors between the red and black wires at the sockets (in other words do I still attach the resistors between A6 and T2 ........B6 to T12?
Thank you! Greg
Reply #22 on: April 13, 2025, 05:23:26 PM
If you just move the wires on the balance pot, then it turns the balance pot into a pair of resistors so there's a ground reference for the input.  You'll want to leave the balance control somewhere close to the center still if you do this, but the effect of turning the balance pot all the way one way or the other will potentially be inaudible.
Offline Mucker
Reply #23 on: April 13, 2025, 05:24:59 PM
Perfect. Thank you Paul!
