Moreplay - Hum in the input-chanel with phono preamp, left chanel cracks[solved]
[email protected] · 35101
When I have run into the problem you're describing, frequently the source of the issue is that earth ground, the chassis, and audio ground are in a state of relative disagreement with each other.  I just debugged an amp with this same problem the other day, and I had to scrape off some coating on a panel that was preventing the audio ground and chassis from connecting properly.  In your preamp, I would look carefully at the tinned buss wire around the IEC power entry module and be sure all your hardware is tight.   When you are connecting the Denafrips, it is temporarily restoring whatever is missing.
Offline Deluk
Where is that black wire connected to? Its counterpart on the other valve looks to go to the adjacent tag strip and the "spare" wire doesn't look to go anywhere near the left one. Photo?
Offline [email protected]
Hi Everybody!
Many Thanks to everybody and especially to those who helped me figuring out the problems!!! It is solved and you where again
absolutely right, I soldered the black cable to the tubesocket for some reasons??? I changed it and now there is no hum at all and it sounds
absolutely devine!
Thank to everybody!
Great Forum!
Jens
