Bottlehead Kits
Kaiju Stereo 300B amp
Kaiju - Headphones
Kaiju - Headphones
hpleung
7042
hpleung
Full Member
Kaiju - Headphones
April 10, 2024, 07:49:56 AM
Hi,
I understand the Kaiju can be used to power headphones - if so, what are the most suitable headphones for the Kaiju? Which impedance range for example?
I also have a paramount 2A3; is it the same answer for the paramount?
Thanks.
Paul Birkeland
Global Moderator
Hero Member
Re: Kaiju - Headphones
Reply #1 on:
April 11, 2024, 06:32:26 AM
The Kaiju is not intended to operate as a headphone amp, but it's sufficiently quiet with the DC filament upgrade and the output transformers wired for 2 or 4 ohms.
You can try any headphone above 2 ohm impedance with the Kaiju. This answer is about the same for the Paramount.
Bottlehead Kits
Kaiju - Headphones
