Moreplay input voltage questions
Tuco · 7873
Offline Tuco
on: June 15, 2024, 05:37:45 AM
While I’m waiting on a Moreplay to arrive, I’ve started work to build a DAC that has an output voltage around 6 volts.  Is a 6 volt input voltage acceptable for the Moreplay?  If this is a potential problem, are there Moreplay modifications that could or should be implemented to address the problem?
Jay Decker
Reply #1 on: June 15, 2024, 05:51:30 AM
Wow, that is spicy! That will be 8.4V peak, but will dip down to 5V peak through the balance control, so you have plenty of headroom remaining.
Offline Tuco
Reply #2 on: June 15, 2024, 07:35:25 AM
Wow, that is spicy!
That is exactly what I said!
It doesn’t sound like you think a 6 volt input voltage will result in a magic blue smoke escaping event, so it full speed ahead on the DAC… though I might get the parts to reduce the Moreplay output gain for lower volume listening since the power amp has plenty of flex.
Jay Decker
