Well, we just finished this amp about 20 hours ago so I can only make judgments that may change as we further refine the circuit. Right now we are exploring the best parafeed cap value. We have increased it from 3.3 uF yesterday to about 13 uF this morning and the bass is now about as deep as a SEX with MQ iron, and it seems a bit better controlled. The lower mids seem a little better balanced now too, yesterday the Smack seemed a little too bright to me. The S.E.X. may be winning in the midrange magic category and it might be a little bit more sweet on top. Might also give a little better sense of depth.
From a technical standpoint, of course the S.E.X. is much more versatile in that it can run efficient speakers as well as headphones. The Smack has theoretical advantages for headphone listening in that it is a single gain stage amp and it is shunt regulated. And if we decide to go into production on the output transformer with the higher impedance taps that might make it a little more universally good for both lower and higher impedance cans. All 6DN7s seem to sound equally good so tube selection is pretty easy for S.E.X. The 5687s and 7119s that work in the Smack seem to come in different flavors and it may take some rolling to find a pair you like. Some like that opportunity to play around, others don't want to bother. S/N may be a bit better in the Smack. I will need to cut the HVAC in the building to make a judgment about that, as the noise floor is pretty low in both amps.
« Last Edit: February 16, 2011, 12:24:29 PM by Doc B. »
