WHING~~~~ I hear a hum noise. [resolved]
yoonbs · 7228
Offline yoonbs
on: June 26, 2024, 12:47:18 AM
Hello.
I assembled the S.E.X Kit a while ago.
I also assembled the CS42.
The resistance and voltage are within the range.
The sound is good.
However, a constant buzzing noise is heard.
A constant hum noise is heard regardless of the volume change.
I checked terminal 29 or 36, but they are not in contact with the nut.
Where should I check?
« Last Edit: June 28, 2024, 05:01:41 PM by Paul Birkeland »
Offline AllenS
Reply #1 on: June 26, 2024, 02:21:18 AM
Sorry to hear about troubles...
You don't mention if there is a source connected or if the buzz is in headphones or speakers.  Both?
Have you moved to another room and power source as a test against wifi interference?
Offline yoonbs
Reply #2 on: June 28, 2024, 01:10:38 PM
Soldering again fixed the problem.
Thank you.
