Right channel hiss [resolved]
Pharane0 · 1473
Offline Pharane0
on: November 19, 2024, 01:34:01 AM
Hello,
I finished building my crack + speedball this summer. But since the build, there is a noticeable slight hiss / static / white noise coming from the right ear of my headphones. This hiss happens even without the input RCAs plugged in. It also happens even if the volume pot is all the way to 0 or OFF. I tried my HD6XX and then HD800S with the same result. I tried plugging the amp in a different socket and then in a different room in the house with the same result.
To give you a bit more info on the hiss, here is what happens chronologically when I start the amp :
1. First instant, a "surge" of hiss in the LEFT channel
2. Quickly this LEFT hiss disappear and becomes inaudible
3. Then a surge of hiss in the RIGHT channel (as if it transferred from left to right, but i'm not sure if that's thing in electronics or not)
4. The right hiss kinda progressively becomes quieter but is still audible and that"s the issue
The amp passed the voltage tests present in the manuals. I think, if i remember correctly, that this hiss was present even before the speedball upgrade. I though the speedball would reduce it to zero but I was wrong. Today I re flowed all the solder joints with a bit more solder. I also checked continuity with a ohm-meter. This unfortunately didn't solve the issue. I "cleaned" the tubes pins by inserting them repetitively, didn't solve it either.
Now I don't really know what else I could check, so if you have experience with a similar problem, can I ask for your help please ? I'm thinking about ordering a set of tubes to see if the problem comes from the tube but if you have any idea before I order them please feel free to tell me. Thank you ! :)
« Last Edit: November 28, 2024, 06:37:22 AM by Paul Birkeland »
Reply #1 on: November 19, 2024, 03:26:29 AM
Trying different tubes may be a helpful datapoint for something like this.  How long have you run the amp with the tubes you have now?  Sometimes you'll need to let the tube set you have run for a few days straight to allow the tubes to get nice and hot and issues like this will clear on their own.
It's also worth noting that you can poke around the circuit with a wooden chopstick to see if there's a spot you can poke that produces or changes this noise, and that can help direct your resoldering efforts.
Offline Pharane0
Reply #2 on: November 28, 2024, 01:54:22 AM
Okay, you can mark this thread as [SOLVED]. The culprit was the small tube in the front from the beginning ! Changed it to a ECC82 / 12AU7 JJ ELECTRONIC and the amp is dead silent ! I'm glad this resolved my problem ! Cheers  :)
