issues with resistance check [resolved]
riskybusiness · 1347
Offline riskybusiness
on: November 21, 2024, 07:02:53 PM
Hello,
finished my crack build but when applying the resistance check I am getting the wrong measurements. for instance when black lead on u12 and testing the ground my values are 1.35ohms, and when testing u12 and terminal 3 value is 1.32 ohms. what can be my issue?
thank you
« Last Edit: November 22, 2024, 02:41:29 PM by Paul Birkeland »
Online Tom-s
Reply #1 on: November 21, 2024, 07:23:08 PM
If you touch your test leads together. What's the resistance it reads?
Reply #2 on: November 21, 2024, 07:34:03 PM
ok yes, i get the same value of 1.37ohms
Online Tom-s
Reply #3 on: November 21, 2024, 08:22:31 PM
Hope this helped and you can now safely continue your journey with the Crack.
Good luck!
Reply #4 on: November 21, 2024, 09:20:10 PM
Yes it did. Thanks
